#21 |
I'd clean the carbs and see how you go. Could just be a bit of something stuck in one of the jets.
#22 |
I reckon some crap in the pilot circuits somewhere. Sounds lean.
#23 |
It also picks up to about 4k revs on the choke as soon as you apply the throttle but not sure if thats normal for this bike. Im thinking carbs probs next logical step...Yup i check the oil frequently-ish. Ive just done an oil and filter change too so its all fresh. How can i test the coils if they are intermittent?
#24 |
You can't test them for that. Make sure carbs are spot on first as that could explain surge. Coils cannot explain surge but they could cause hesitation on pickup.
#25 |
Fair enough, i was thinking it was fuel related and it seems more likely. Would it be worth looking into getting them ultrasonically cleaned or a diy job? If the pro cleaning is worth it, what sorta £ am i looking at?
#26 |
DIY job. Carb cleaner and an air line.
#27 |
check the vacuum hosing for cracks, engine breather for blockages and tank for rust. how old are the plugs?
i always check to carbs is working first then i do carb clean. no point in cleaning carbs if something else is wrong before carbs. |
#28 |
Tank wont be rusty as it was fine when fitted in august. Plugs not too old and their iridium. Dont think breathers blocked as i get a bit of oil in the airbox
#29 |
Which is the vacuum hosing, the vacuum from the tank to the carbs?
#30 |
Other way around but yeah, if that's got an air leak it won't help at all.
GSXR 750 SRAD '97 - Project | Griff-SV | For Sale - Other Bikes and General biking items | 8 | 28-10-12 05:01 PM |
GSXR 600 SRAD restrictor kit | Uu Mr.E uU | For Sale - Other Bikes and General biking items | 1 | 19-04-11 10:54 PM |
98' srad gsxr | Baph | For Sale - Other Bikes and General biking items | 9 | 28-10-09 04:23 AM |
stutter on constant throttle on FI bike | Loser | SV Talk, Tuning & Tweaking | 15 | 06-06-09 02:41 AM |
