Old 03-04-14, 10:08 PM   #21
AkiraSV
Default Re: Potential dumb question time re bleed nipples
Hmm, bit more reading round regarding the ptfe tape and it seems opinion is split.
Times like this I just want to get rid of the bloody thing.
Old 03-04-14, 10:36 PM   #22
sputnik
I am still sticking with my unscientific theory of just unwinding the bleed nipple a touch. I am only talking about a tiny adjustment, say 5 degrees, if that. And make sure the threads are totally clean. My ones had a recurring damp stain around the top of the caliper or visible wetness at the lowest bit of visible thread either overnight or after any ride, immediately after doing a brake caliper clean up. Very slight slackening and twas gone.
Not sure I'd want to be looking at a track day with brakes I didn't have full faith in given the extra stresses they'll likely be under.
Old 04-04-14, 10:55 AM   #23
aesmith
PTFE seems a bad idea, it'll get minced when the bleed nipple's slackened off for bleeding, then can't be replaced except by completely removing the nipple. Personally if you're worried I'd go for a dab of silicone or red rubber grease.
Old 05-04-14, 07:59 PM   #24
Winder
Winder's Avatar
If it makes you feel any better i have this on my k4 SV, the brakes work sweet and everytime i have serviced the brakes or bled the brakes it hasn't got any worse or better.
I'm not bothered about it and ride my bike most days.
Old 06-04-14, 06:50 PM   #25
AkiraSV
Red rubber grease? I've got some of that kicking round too - around the threads or just where the threads come out the face of the caliper?
Interesting, how long has this been occurring?
Old 07-04-14, 10:41 AM   #26
Winder
Winder's Avatar
since i've owned it, just over a year now
Old 07-04-14, 11:47 AM   #27
IF you think about how a bleed nipple works then PTFE tape is silly.
There's a ruddy great hole in the thing below the threads!
You've got a metal-on-metal seat.
First method, slacken and tighten it a few times.
If that doesn't work: Remove nipple, clean it, flush a little bit of fluid out. Retighten.
If that doesn't work then get a new nipple and recut the seat.
Old 24-04-14, 01:28 PM   #28
AkiraSV
Didn't go down the PTFE route in the end. Instead tightened up a bit more (whilst cringing slightly, I must admit). Seems fine now, track day went fine and the brakes were really, really good.
Bikes are silly.
Correct bleed nipples for Pointy? AkiraSV SV Talk, Tuning & Tweaking 9 12-10-13 04:50 PM
bleed nipples Nicky S SV Talk, Tuning & Tweaking 11 23-05-09 12:18 PM
HEL Replacement Bleed Nipples don't fit SV Ruffy SV Talk, Tuning & Tweaking 5 13-05-08 09:00 PM
Bleed nipples svrash SV Talk, Tuning & Tweaking 10 24-11-05 06:33 PM
Damaged bleed nipples? r1ck SV Talk, Tuning & Tweaking 12 11-03-05 10:01 PM
