#21 |
Throttle body balance and TPS setup if never been done would be a good start point. Plus that can will mess up your fueling and can cause a cough low down as most SV's with exhausts like that run very rich low down.
#22 |
Regarding the oil usage, if you've used fully synthetic oil right from the start the piston rings may not have bedded in. Perhaps use cheap mineral oil for a while until oil consumption is reduced, then change back.
#23 |
nah used semi from the get go....
#24 |
Should have thrashed it harder
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#25 |
I think all the popping and coughing and sneezing was due to lack of back pressure from the exhaust... Made a baffle and now it's gone... As for the oil I think that is normal the level has not changed over the last couple of weeks....
#26 |
I can confirm that all is well, changed the exhaust back to my Leo vince and she is running fine again. It's been a month and no issues.
Engine noise - K6. | Xpistos | SV Talk, Tuning & Tweaking | 4 | 11-02-13 12:50 PM |
k4 engine noise on over run | all the gear | SV Talk, Tuning & Tweaking | 2 | 28-08-11 06:57 AM |
engine noise | mouldy | SV Talk, Tuning & Tweaking | 1 | 16-04-10 07:00 AM |
engine noise | mattbike | SV Talk, Tuning & Tweaking | 3 | 29-10-09 12:09 PM |
Engine Noise | Torn-Thorax | SV Talk, Tuning & Tweaking | 1 | 02-12-06 07:56 AM |
