#21 |
So not forged. I wonder what the advantages of that method are? Forging gives greater strength and durability as it aligns the grains of metal. I can't imagine a cut steel sheet having the same benefits.
Silver SV650SK3, Fuel exhaust |
#22 |
Think how much unsprung weight having two cast disc's on the bike would be.
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#23 |
If they were cast in the same shape and size as they currently are, I can't see it adding any weight. I don't think cast steel is significantly denser than sheet steel. Might be a wee bit brittle though.
#24 |
Rather you than me
#25 |
I'm no expert on metal processes but I'm pretty sure sheet steel is produced from a forging process where the steel is put through a series of rollers to get to the desired thickness. This process results in a more uniform alignment of the metals elements (I don't know the technical terms, I'm sure someone on here will correct me if needed) which gives it a far greater strength than the casting process where they are still in an unworked random order.
