Old 07-03-15, 09:18 PM   #21
wideguy
Default Re: brake pistons
ceramics have come a long long way in recent years and they now make high speed bearings with it. the new bread of ceramics are tough as fek.
One of the benefits of ceramic bearings (besides lower rolling friction) is cool running. Maybe running cool helps keep friction down?
Ceramic brake pistons probably don't transfer much heat to the brake fluid, which is a good thing.
Old 07-03-15, 09:25 PM   #22
wideguy
That is true.
I think it's years away before being viable for vehicles. Saying that if they start using them in WSB or BSB, it'll be 5 years from then before brembo produce a road suitable version
Good suitable road going brakes are here now. If you need racing brakes on your street bike, you should take it to the track. Actually modern sport bikes have racing brakes from the factory.
If ceramic pistons were cheaper, we'd likely have them now on everything. If they work better, then WSB and GP bikes already have them.
Hard braking at every corner, especially from high speeds, will sometimes overheat common brake fluids, but you can use uncommon fluids if you're racing, and if your street riding includes hard braking from high speeds at every corner... wouldn't you be racing on street circuits?
Old 07-03-15, 09:47 PM   #23
And maybe dissipate heat quicker than metal pistons?
Probably lighter too?
Old 25-03-15, 06:58 AM   #24
DryRob
I think they might use impact extrusion to make the rough shape and then turn them on a lathe to get the dimensions more accurate. It'd save tooling costs over turning them from a solid piece.
They're probably hollow to save money on material as well as reduce expansion effects
Bikerstoolbox.co.uk sell different tools to suit your budget, I just got the mole grip type tool since the cheaper ones were rubbish.
DryRob is offline   Reply With Quote
How to clean brake pistons? BBadger Bikes - Talk & Issues 8 19-05-10 11:50 AM
Best way to clean up brake pistons? curium SV Talk, Tuning & Tweaking 12 06-04-09 09:42 PM
Brake Pistons? vardypeeps SV Talk, Tuning & Tweaking 4 29-08-08 12:12 PM
new brake pistons and seals. where from? raymond smith SV Talk, Tuning & Tweaking 2 30-04-05 09:24 PM
Rear Brake Pistons JMCHITTOCK SV Talk, Tuning & Tweaking 8 22-02-05 09:23 AM
