#21 |
B & Q did a copper pipe repair putty.
Worth a look.
Raisin cookies that look like chocolate chip cookies are the reason I have trust issues. |
#22 |
I've radwelded and superglued the outside. It appears to be holding firm after 100+ miles.
#23 |
Super glue dissolves in water
Use araldite or similar
#24 |
Radweld is not a good shout, if it was me I would flush all the coolant out, fill the rad with water a couple of times, drain that and replace with coolant. Please.
Like some of the others here I have used Epoxy (araldite) to replair a rad before. To fix an area live the one you have I cut the fins away carefully above and below the leak with a knife, then rubbed the bar with the hole with some fine wet & dry to key the surface and used Araldite and some cloth or wire to make a wrap around the bar, then I let it dry. A light spray of black afterwards and you couldn't see it unless you looked. Jambo
#25 |
My dad used to own a radiator repairers, so I have plenty of experience as a kid of repairing rads. There is only one sure method. A re-core.
Otherwise, you need to remove the top/bottom tanks and then soak the core in an acid bath to clean it. Then a blob of solder at either end of the holed tube. Reassemble core/tanks. To test, blank hose fittings with a rubber bung, a washer either side and a nut/bolt through. As you squeeze the bung, it expands to seal the hole. fit an air line with about 3-5 psi and drop it into a water tank and looks for leak bubbles. If OK, refit. Careful with the pressure you do not want to rupture the core and make sure those bungs are tight. I have seen them fly 30ft smashing a window on their way. Sounds like hard work, it is. that is why it costs for a repair. Especially with modern plastic tanks that need to be bonded. Old fashioned soldered was far easier.
Not Grumpy, opinionated. |
#26 |
#27 |
you can get pipe repair putty that is two part, just mix and squeeze on.
#28 |
Yep this
Accumate permanent connection | sauluk | Bikes - Talk & Issues | 5 | 01-04-10 03:36 PM |
The most excellent, permanent repair ever. | captainsmelly | SV Talk, Tuning & Tweaking | 22 | 16-07-09 02:06 PM |
2011...all cars to have permanent lights on | Frank | Idle Banter | 53 | 27-02-08 12:27 PM |
Getting Permanent Marker Off Paint | thor | Bikes - Talk & Issues | 11 | 10-05-05 09:53 PM |
Permanent Marker on my Helmet.... | Scoobs | Bikes - Talk & Issues | 6 | 26-04-05 02:12 PM |
