Old 27-11-16, 11:40 AM   #21
Blapper
Blapper's Avatar
Default Re: Curvy RHS
Folding rear brake lever on the way, anybody any ideas for a good body shop?
Old 29-11-16, 11:29 PM   #22
Dipper
Dipper's Avatar
Careful with these, I couldn't find any that lined up properly with the master cylinder ....if your's is a good fit if you wouldn't letting me know where it came from I'd be grateful.
Dipper is offline   Reply With Quote
Old 03-12-16, 08:00 AM   #23
Blapper
Blapper's Avatar
Hi Dipper
My folding lever came from eBay and cost £32 delivered.
It fits, but has the following problems: Listed as for an SV650/S it is actually a 'universal fit' item (that's code for doesn't fit anything properly). It has a couple of kinks in it which the original doesn't and so it needlessly swerves away from the engine, plus - and most importantly - it has a cast feature which projects inwards to take the return and rear brake light springs which is wrong for the rear brake light as it is too low causing the spring to be under too much tension and so the light is on all the time.
In short, it will do at a pinch if you don't want a rear brake light, but I'm sending it back.
HTH
Swap curvy SV650s for naked curvy SV650? rezus17 For Sale - SV's and SV related items 0 31-03-14 09:43 AM
Speedo from a curvy S fit into a curvy Naked housing? Taipan SV Talk, Tuning & Tweaking 6 18-02-10 04:59 PM
Naked Curvy Bottom yoke and Curvy speedo drive 21QUEST Stuff Wanted 6 29-01-09 09:36 AM
thought i best post some here, curvy lowers on my curvy BIKER-DENE Photos 3 06-05-06 07:26 AM
