#21 |
The one on sl0th's bike would have torn that spot welded nut clean off. What with that and the ridiculously (2000Nm) tight front sprocket nut, it is clearly the work of a cretinous mekanik.
#22 |
Quite possibly - frustratingly, I bought the replacement in advance and then still had to buy a filter wrench to get the old one off, so could have bought a standard one.
#23 |
#24 |
With ,"Spin-on" oil filters they usually recommend smearing some clean engine oil on the rubber seal.If this isn't done they can become more difficult to remove as the seal can dry out and bond to the metal.
HTH ![]() |
#25 |
I need to replace mine before I start riding again this year. When I changed it last year, I'd tightened the previous one up by hand only and smeared oil on the seal but still needed an adjustable wrench around the base to get it off. The constant heat and expansion/contraction of the metals must contribute in some way to making them more difficult to remove.
#26 |
They all get tighter as time passes due to heat/cold and the smear of oil being squeezed out I suppose but with the short oil change interval of the SV this shouldn't happen. Mine only required light pressure on a socket ratchet handle to remove it.
#27 |
I only tighten mine by hand (and even then not very tight) and I then have a large jubilee clip that slips over the filter and gets tightened up. The jubilee clip is wired to the bike. This effectively prevents the filter from rotating and coming undone. Rarely have to use anything other than my hand to remove them come service time.
#28 |
I turn until the oiled rubber touches up to the mating face then give 1/4 turn. You and I will not have a problem I'm sure.
#29 |
I have subscribed to Delboy's Garage on YouTube and he uses the term "gorilla it" for over-tightening which is apt.
Your situation is odd as we all want to make our lives easier so I guess gorilla tightening did not happen, but think of every job you do, corrosion is the SV's thread-lock on everything you need to loosen!! Considering the oil filter gets all the shiz picked up by the front tyre that could explain it.
Thought I was in a bad mood, but it's been 30 years now, so I suppose it's just who I am. 05 SV650s now with proper suspension, hurrah! |
#30 |
If you do the filter up with bare hand it should come undone ok with a rubber gloved hand. That was my technique for years without a problem. As Suzuki provide a tightening torque figure for the SV filter I do it up to that figure with a filter socket and trusted torque wrench. Seems tighter than I would normally have gone to with my hand but still comes off fine. Unless you know your wrench is calibrated, better to do up by hand I reckon.
Haven't been on here recently. | Felix_ | Photos | 10 | 03-08-12 09:39 PM |
What U-turns have you done recently? | Nobbylad | Idle Banter | 13 | 27-10-11 07:37 PM |
Done anything silly recently? | Jayneflakes | Photos | 16 | 18-09-11 07:49 AM |
Hobby - have you taken one up recently? | Miss Alpinestarhero | Idle Banter | 55 | 09-07-09 05:24 PM |
Not been recently. | REEVESIE | Soho Massive | 2 | 02-12-05 12:05 AM |
