Old 06-01-18, 03:26 AM   #21
Dave-the-rave
Dave-the-rave's Avatar
Default Re: 2005 SV650s Valve Clearance Question
I'm doing this from memory so wait until someone else chimes in to confirm what I'm saying.
Valve check procedure...
Front cylinder
F mark lined up on the rotor at TDC means front cylinder cam lobes facing up and leaning slightly outward.
Rear cylinder
R mark lined up at TDC means rear cylinder cam lobes facing up and leaning slightly inward.
To remove cams for adjustment...
F mark lined up front cylinder at TDC as before. Timing marks should line up on front cylinder. If not rotate 360 degrees to F mark and check again. Take out the front cams.
This is the counter intuitive part regarding the rear cylinder...Rotate the crank 360 degrees until the F mark shows again. The rear cylinder timing marks should now be lined up. Remove the cams.
Note.. The R mark is not used during removal or installation of the rear cylinder camshafts.
SV650N K1
Dave-the-rave is offline   Reply With Quote
Old 06-01-18, 10:53 AM   #22
SV650rules
Originally Posted by egcSV650s View Post
Finally got round to getting the shims out and going by the chart the shims go up in .05 but ive got some shims which are saying 172 and 178?
Also i TDC the rear cylinder but the sprockets dont line up where there meant to be for TDC. The crankcase shows TDC but the markings on the sprockets dont. Ive attached a picture, black marking is where the markings are and red markings is where they should be. Can i just move them round to where there meant to be or will this cause problems
(Wont let me upload picture as its jpeg)
Try copy and paste of photo into MS Word document and either 'save as' older .doc (not more recent .docx) or save as PDF (a 'save as' option in MS Word) and post, it works for me as long as file not over size limit (don't try more than a couple of photos in one file). File size shriks a lot when saved as PDF and a little bit of definition lost but not really too bad.
2016 SV650 AL7
Old 07-01-18, 09:13 PM   #23
egcSV650s
Managed to attach them as pdf's quality isnt that great but hopefully you can see
egcSV650s is offline   Reply With Quote
Old 07-01-18, 09:37 PM   #24
Dave-the-rave
Read my previous post.
Go back to the front cylinder and set the F timing mark on the crank until the front cylinder camshaft timing marks line up. Now rotate the crank a full 360 degrees anti clockwise until the F mark lines up again. The rear cylinder cam timing marks should now be lined up.
Ignore the R mark on the crank.
SV650N K1
Old 07-01-18, 10:46 PM   #25
egcSV650s
Oh right i understand what you mean now, ill have a go at it next weekend as im away this week
Old 07-01-18, 11:29 PM   #26
Dave-the-rave
Let us know how it goes.
SV650N K1
Old 10-01-18, 07:10 PM   #27
egcSV650s
Front cylinder
Rear cylinder
Been wondering, how comes when adjusting and removing the cams you have to have the mark on F and not R? Does it matter if you have it on R and remove the cams?
Old 10-01-18, 10:17 PM   #28
Dave-the-rave
The timing marks on the rear cylinder cam shafts won't be properly aligned if the crank is set on the R mark, which without seeing your bike I suspect is where you are going wrong.
Don't remove the cam shafts on any cylinder if the cam timing marks arn't aligned like the books show.
They also need to be aligned as the book shows before removing or installing the cam chain tensioner.
SV650N K1
Old 11-01-18, 07:47 AM   #29
egcSV650s
What happens if i do remove the chain tensioner and cams once its on the R mark as thats what ive done. Ive put it all exactly back where it is now though
Old 11-01-18, 12:45 PM   #30
Dave-the-rave
I'm not sure what you mean by ''put it all back exactly where it is now''. If you have installed the rear cams incorrectly the valves will hit the piston when you spin the motor so don't spin the motor. Assuming the front cams and tensioner are all in place here's the easiest way to fix the rear without damaging anything...
Remove the rear tensioner and cams.
Turn the crank anti clockwise until F mark is lined up
Check front cam timing marks are lined up if not rotate crank 360 to F
You'll have to hold the rear cam chain up and on the sprocket by hand
when turning the crank or it can get stuck.
So now the front is on F and front cam timing marks are aligned.
Turn the crank a full 360 degrees anti clockwise back to the F mark again.
The front timing marks will now not be lined up but that's ok.
Install rear cams ensuring timing marks line up as per the book.
Install chain tensioner.
Do all of the above with both spark plugs removed.
SV650N K1
valve clearance/service/leakdown question sputnik SV Talk, Tuning & Tweaking 13 29-03-14 02:51 PM
Quick valve clearance question arcdef SV Talk, Tuning & Tweaking 4 29-06-10 03:48 PM
quick valve clearance question rob13 SV Talk, Tuning & Tweaking 2 12-02-08 12:14 PM
A question of valve clearance... BillyC SV Talk, Tuning & Tweaking 11 23-11-05 12:36 AM
Valve Clearance Craig SV Talk, Tuning & Tweaking 3 14-02-05 07:34 PM
