21-07-18, 11:41 AM | #21 |
Re: Pointy no spark
Does the FI light come up as soon as you turn on the ignition or only when you try a start? And the procedure youre using for code testing is definitely: ignition off, put dealer mode wire into connector block, turn ignition on, try start and look for code?
The only suggestion Ive got isnt nice but could the ECU be knackered? You can either try to swop it with a very good friend's unit or go to your dealer....... |
21-07-18, 03:05 PM | #22 | |
Re: Pointy no spark
Thanks
He was a hairy handed Gent who ran amok in Kent Awhooo |
22-07-18, 11:19 AM | #23 |
Re: Pointy no spark
Picked up an other ecu locally, still the same!!!!!!!!!!!!!!
Trying to make a choice now, dealer or bonfire
22-07-18, 12:10 PM | #24 |
Re: Pointy no spark
just to recap what you have:
water temperature reading has gone and in its place 'FI' letters indicated continuously, to the left of the speed reading 'FI' letters indicated and blinks, red oil pressure/FI light on and blinks. |
22-07-18, 01:35 PM | #25 |
Re: Pointy no spark
FI comes on solid with the ignition on, no blinking, FI light goes when I hit the starter button
22-07-18, 02:46 PM | #26 |
Re: Pointy no spark
Not done any of that, its getting into areas I dont have any experience of
22-07-18, 03:02 PM | #27 |
Re: Pointy no spark
And do you get the two lots of 'FI' letters or not? If not then its not indicating an FI fault but oil pressure and is correctly going out when the motor turns over and pressure builds up.....
22-07-18, 03:09 PM | #28 |
Re: Pointy no spark
Only 1 FI not 2 so does that mean that I have been "barking up the wrong tree"
22-07-18, 03:31 PM | #29 |
Re: Pointy no spark
so where are the letters 'FI' showing, below the speed reading where engine temperature normally shows or to the left of it?
22-07-18, 03:52 PM | #30 |
Re: Pointy no spark
Unfortunately everybody calls the red warning light the FI light but it can also indicate a high coolant temperature and low oil pressure.....
Spark plug gap? Pointy. | Red ones | SV Talk, Tuning & Tweaking | 3 | 24-01-15 04:03 PM |
Spark plug failures. Pointy. | cosh | SV Talk, Tuning & Tweaking | 3 | 06-03-14 06:50 PM |
Single spark loom, Pointy. | tetol | Stuff Wanted | 0 | 26-02-14 05:24 AM |
What spark pugs do you use? Pointy. | Longway | SV Talk, Tuning & Tweaking | 12 | 25-06-13 07:53 AM |
Spark plug socket - Pointy? | XmisterIS | SV Talk, Tuning & Tweaking | 10 | 22-02-12 03:51 PM |
