Old 03-11-19, 03:00 PM   #21
daktulos
daktulos's Avatar
Default Re: Curvy power problems
Originally Posted by R1ffR4ff View Post
Do a Diode test on the R/R.The procedure is in the manual and pull apart and clean the in-line block connectors.My Curvy had two but I've now removed them as per,
https://cx500.000webhostapp.com/Mosf...sfetUniRR.html
Cheers - I tested them as per the ElectroSport flowchart, and all was good. The blocks were pretty good, voltages were taken from the R/R side of the block.
Originally Posted by embee View Post
I think you're spot on. You should be seeing 14 point something volts when revved. At this point I'd suggest stop trying to over-analyse and simply replace the R/R.
Thanks for your advice. If replacing, I'd probably go with an Electrex one, which I've seen mentioned before - it is the right size and has the right connection blocks, so would be simple.
I did a few more tests today, including current. I won't bore everyone with all the numbers, but at 5000rpm the bike was drawing 2.1A from the R/R and 4.0A with the headlight on. That's less than the 4.5A expected for the headlight, so (at the battery's current charge level) the battery will be discharging to power the headlight.
Not really conclusive. So, as embee suggests, I'm going to stop over-analysing it. I'll either live with topping up the battery occasionally, or buy a new R/R.
Thanks for everyone's help.
daktulos is offline   Reply With Quote
Old 03-11-19, 04:10 PM   #22
R1ffR4ff
R1ffR4ff's Avatar
Even if they look good you should clean them.I use a small electrical screwdriver with some 500 grit paper wrapped around and poke into the females and scrape them all clean.Then blast with Switch/Contact cleaner and in my case then treat with ACF50.
Halfords do some Contact cleaner if you need some local,
https://www.halfords.com/motoring/en...cleaner-500ml#
Old 03-11-19, 05:58 PM   #23
johnnyrod
johnnyrod's Avatar
I'm with Embee, RR is kaput
Old 27-11-19, 11:11 AM   #24
daktulos
daktulos's Avatar
So, in case anyone was wondering, I've finally replaced the RR with an Electrex one (very straight forward - slightly larger, but fits. It bypasses the little 3-phase extension cable which I left in place, and needed two new longer bolts).
I now have around 14.4V at the battery at idle & 5000rpm & a noticeably brighter headlight. Case closed!
Old 27-11-19, 08:53 PM   #25
mikerj
Batteries simply don't work as well in the cold, and the impact of low temperatures becomes far more noticeable when the battery is nearing the end of it's life. As others have mentioned, measuring the battery voltage under cranking will tell you how healthy it is, and measuring it with the engine running will give an indication of how well your charging system is working.
Another possibility is that you have a high resistance connection somewhere within the high current starter circuit e.g. loose or corroded terminals, bad solenoid, or the starter itself is getting tired.
Old 27-11-19, 10:54 PM   #26
daktulos
daktulos's Avatar
Thanks, but it's sorted now.
Curvy down on power. baldricc SV Talk, Tuning & Tweaking 9 18-03-14 10:38 AM
Loss of power - Curvy. juliensc SV Talk, Tuning & Tweaking 5 05-10-13 12:12 PM
Slight power delivery type problems. Dave20046 SV Talk, Tuning & Tweaking 11 19-06-09 10:46 AM
pointy power and vibration problems pookie SV Talk, Tuning & Tweaking 4 17-10-08 07:26 AM
curvy 650 power problem adam_castell SV Talk, Tuning & Tweaking 4 27-08-08 08:30 AM
