Old 09-09-21, 09:03 AM   #21
Seeker
Seeker's Avatar
Default Re: Running problem driving me nuts!
How did you check for air leaks? One way is to spray suspect areas with carb cleaner (with engine running) and listen for a change in the way the engine runs.
2016 SV650AL7
2023 GSX-8S
Old 10-09-21, 07:56 PM   #22
R1ffR4ff
R1ffR4ff's Avatar
Try swapping the plug caps and see if it has an affect?
If it does read here or have a look anyway,
https://cx500.000webhostapp.com/SV65..._And_Caps.html
Faulty plug caps can be sneaky little buggers especially in rain.
Old 31-10-21, 06:54 PM   #23
Blapper
Blapper's Avatar
Well guys, This one has me beat. in 51 years of building/riding bikes I have never been beaten but this one did it. I finally took the carbs apart for the third time and found nothing so I reassembled them carefully swearing at every part and fired it up. Voila! Ran fine so I put it on facebay and flogged it in two hours.
I want to thank you all for your help on this and every other post I have done on here.
Regards,
Andrew,
Old 02-11-21, 12:45 PM   #24
garynortheast
garynortheast's Avatar
I must confess that I'm quite sad that you've got rid of that lovely curvy, Blapper.
Blue Curvy S with over 111,000 miles and still going strong.
Old 16-11-21, 12:17 PM   #25
Blapper
Blapper's Avatar
Thanks Gary. I have to say it was the nicest bike to ride that I've had (after I did the straight bars conversion). Wonderfully neutral handling and quick enough for todays roads.
Thanks to @R1ffR4ff, @Bibio, @embee, @Biker Biggles and everyone else who passed on their knowledge and experience which made owning my SV an even more enjoyable experience.
Old 16-11-21, 05:53 PM   #26
garynortheast
Well, don't disappear from the Org, just because the curvy has gone doesn't mean you're not welcome.
k2 curvy running problem Nicky S SV Talk, Tuning & Tweaking 32 09-08-10 05:36 PM
Mrs w is driving me nuts! Bri w 2010 Annual Rideout 18 05-08-10 03:30 PM
Computer is driving me nuts maviczap Idle Banter 6 01-12-09 04:05 PM
running problem - as if running out of petrol Nick8529 SV Talk, Tuning & Tweaking 20 27-10-09 11:47 AM
And you thought running out of oil was a problem... gettin2dizzy Idle Banter 22 11-06-08 08:04 PM
