Old 22-03-22, 07:36 AM   #21
daktulos
daktulos's Avatar
Default Re: Do you refuel on the side stand or centre stand/centred?
Originally Posted by EssEllTwo View Post
Ok, I must be lucky then, I've never seen £100 authorisation come up on a pump, only only £1.
As I understand it, it's a pre-auth, so you're charged £1 but with £99 reserved - you won't see it anywhere except in your "available to spend" total which will be lower than your balance + overdraft if you have one.
daktulos is offline   Reply With Quote
Old 22-03-22, 06:30 PM   #22
EssEllTwo
The £1 wasn't charged to me, it was only authorised. It was not debited from my account, but as you say, it was removed from my "Available to Spend". There was no £100 or £99 doing anything, Park Royal Asda is not doing £100 pre-auths. The full £75 fill up is showing as a debit transaction today.
Whilst it will not send you into overdraft, I can see it causing issues if you are running close to the wire and it blocks money you have in credit but can't use.
EssEllTwo is offline   Reply With Quote
Old 24-03-22, 12:29 PM   #23
you are only charged for what you use at PAP. the authorisation is to check that you have sufficient funds available. some places are different amounts and i know that Morrisons is £100 but some are £1 which is just a token to make sure that your account is active. its up to you to know how much money you have available in your account. if you dont have the £100 then you will have to use somewhere else or PAK. there is no buy now pay later.
BTW the pump cuts off at £100 but you can just return the nozzle and do it all again. this is going to be getting more common with current fuel prices.
of course you can always pay by cash.......
Old 25-03-22, 11:59 PM   #24
60-80
Junior Member
The difference between the two methods is trivial, so do whichever you prefer.
60-80 is offline   Reply With Quote
Old 26-03-22, 07:09 AM   #25
Seeker
Seeker's Avatar
Being a worrier, if I refilled sitting on the bike I would have visions of the pump not shutting off, filling my lap with petrol which then ignites from the static as I slide off the bike and me running around with a burning crotch.
I get off the bike to fill up
(as an aside, I filled up two days ago at Esso and there was a warning on the pump saying that it might not automatically shut off and requested that you be careful)
2016 SV650AL7
2023 GSX-8S
Centre stand on SV SV650rules SV Talk, Tuning & Tweaking 11 22-07-19 07:47 PM
Centre stand Trev B Stuff Wanted 1 17-09-15 04:22 PM
NWS centre / swingarm stand. Like abba stand quik_d For Sale - SV's and SV related items 4 15-04-13 09:24 PM
Storage: Side stand or rear paddock stand? Maudster SV Talk, Tuning & Tweaking 19 20-01-07 04:45 PM
Centre Stand drumwrecker SV Talk, Tuning & Tweaking 6 05-12-05 11:14 PM
