#21 | |
If that point gets closer then the bend is tightening, if futher away the bend is opening up. the SV's engine is very good for braking so can be used to scrub off speed without using brakes mid-corner, even sudden down shifting isn't a problem as the bike is so light, you can control a slight slide with your thighs. ( Oh, by the way, trailling the front brake through corners, is one of thoughs skills you have to be very carful with, it's easy to over-cook it, and the consequences aren't nice.) If in doubt, do all your braking in a straight line before the hazard. Cheers Mark.
#22 |
The words that worked wonders for my cornering back in the days before the bike got bent:
In wide and slow.... out tight and fast ![]() Much better to go in slowly and accelerate, than find you're entering the corner too fast, and it's too late to slow down safely - expect you've learnt this already! ![]() Also, entering wide (not too wide mind!) ensures that you get to see as much of the oncoming bend as you possibly can, allowing you all the more information to make your judgements.
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#23 | |
#24 | |
Try slowing rapidly using just the rear, your body will move forward. Its physics. ![]() |
#25 |
maybe im not phrasing it right....when travelling at speed (eg upwards of 30) using the rear brake WILL cause lightweight at the rear because you have moved the momentum of the bike to the front...hence less grip on rear....if on the other hand you use the front brake at speed you still shift momentum to the front but this time you have the added bonus of more weight on the front...hence better stopping power and (hopefully) grip.
does this make sense or am i just mad......
tune in, turn on, burn out |
#26 |
You're right, and that's why the front's better than the rear, but it's not an either/or thing... I've only had to out-and-out emergency brake twice, once I ended up actually hitting the car at low speed, if I'd just used the front I would have hit harder and maybe actually done some damage or come off. The other time I came up about a metre short, so maybe I'd have hit without the rear.
Running 120/70 profile front tyres | Tim in Belgium | Tyres | 7 | 14-02-08 04:49 PM |
Fabbri Double Bubble Screen Suzuki Sv650s | talkinbikes | For Sale - SV's and SV related items | 4 | 04-02-08 09:02 AM |
Running in new tyres | cdrsimmonds | Tyres | 0 | 19-03-07 03:08 PM |
Running different tyres F & R | bobit69 | SV Talk, Tuning & Tweaking | 12 | 27-09-06 10:01 PM |
Curvy SV650s Tinted Double Bubble and Lens Covers | Ter | For Sale - SV's and SV related items | 0 | 07-05-06 12:05 PM |
