#21 |
The speedo is driven is off the front wheel on the SV650 so changing sprockets will not affect it and therefore a speedo healer is not needed.
#22 | |
#23 | |
The SV takes the drive from the front wheel as has been stated. Larger rear sprocket means better acceleration. This may cause the front wheel to lose contact with the road surface. Without this traction on the front wheel, it will start to spin slower hence false readings on the speedo. ![]() |
#24 | ||
Moving it to the back wheel / gearbox won't help that much either when you actually spin up the rear tire due to the shorter gearing, giving you again a false reading. ![]() So I'd say you'd be better off with 2 or 3 sensors (front & back wheel + gearbox) connected to a computer, which would instantly average them and give a somewhat more precise reading. Or get a yourself a f'in GPS. ![]() |
#25 | |
calling all geeks(in the nicest name calling way) | jim@55 | Idle Banter | 11 | 25-06-07 08:55 AM |
FAO Jonboy [no one else need look ;-) ] | the white rabbit | Photos | 42 | 17-08-06 08:12 PM |
jonboy, don't look | timwilky | Idle Banter | 20 | 03-08-06 07:13 PM |
calling jonboy :-) | amarko5 | Photos | 18 | 05-06-06 12:46 PM |
Oiy Jonboy !!! | Jelster | Soho Massive | 4 | 12-01-05 07:45 PM |
