Old 27-06-06, 05:54 PM   #21
Ed
I wouldn't mind having the problem of running in a brand spanking new bike
Old 27-06-06, 05:59 PM   #22
timwilky
timwilky's Avatar
There is a school of thought that says simply let the engine warm up and then rag it.
You can get issues that if the cylinder is too smooth then lubricating oil cannot form a proper protective coating.
Having said that I would personally follow the recommended running in procedure.
Tolerences within engines have improved over the past 20 + years. running in used to take off the high spots on a cylinder. modern engines are a lot more consistant and the "running in" is really a liner polish. Hence the concern that glazing could take place
Not Grumpy, opinionated.
Old 27-06-06, 06:27 PM   #23
Abyss
I know its such a pain, i dont know how im going to cope!
Cheers for all the advice guys, I dont think its going to take me long to clock up the 600miles < 5K revs so I'll stick to it as best as poss
Old 28-06-06, 12:44 AM   #24
I'm_a_Newbie
Do 20 to 50 miles up to around 5000 rpm. Change the oil and filter and use ordinary mineral oil, do not use synthetic or semi synthetic. Then ride the bike hard for the next 500 miles or so. At the next service interval you can change to semi or full synthetic oil. This is the only way to get the rings bedded in properly. Treat it with kid gloves and you will have clogged unevenly worn rings and an engine that will be down on power.
Modern engines are machined to much finer tolerances than engines of 20 to 30 years ago when you had to be more gentle. The honing on the cylinder bores is also much finer and once they become polished your chance to seal the rings properly is gone. With this in mind why do people still insist on treating new engines with kid gloves?
More power = more fun
Tim
Old 28-06-06, 07:24 AM   #25
darylB
i suggest letting ed have your bike to run it in, no chance of over revving it , he is a fully fledged iam riding god now
Daryl.
runs and hides.
Old 28-06-06, 08:56 AM   #26
Ed
This is true
Daryl.
This is not. Well, not yet anyhow.
runs and hides.
Old 28-06-06, 09:05 AM   #27
wheelnut
Mine had the gentle treatment for about 100 miles, then I rode it with sensitivity for another 400 miles not going over 6500 rpm. Then I forgot about running it in and did a day at Rockingham.
First Service booked tomorrow :P Then I can give it some, properly
Old 28-06-06, 09:19 AM   #28
Mr Toad
As the man says
Remember (with the greatest of respect) Abyss has only just passed his test (or is about to, fingers crossed) - following the book for running it in will let him get used to the bike. It's a pussycat under 5k revs, and a monster above that - riding hard after the first 100 miles could well end in tears and an early test of the crash bungs
Stick to the manufacturers recomendations more or less and both you and the bike will come out of the first 1,000 miles in good condition
Old 28-06-06, 10:07 AM   #29
Abyss
Yep thats my general plan Mr Toad
If its nice weather the 1st week I have it I dont see it taking long to get everything out of the way
Old 28-06-06, 12:02 PM   #30
arenalife
What you're trying to do is avoid excessive strain, labouring up a hill in a gear under your 5k limit is far worse than higher revs in the correct gear.
Just ride as if you're running out of petrol, easy shmeezy.
'99 SV650 SX Running problems MacDaddySV SV Talk, Tuning & Tweaking 11 20-02-09 07:52 PM
Running rough, running out of ideas. Sarj SV Talk, Tuning & Tweaking 17 04-12-07 06:45 PM
2001 SV650 that wont stay running Farmer-al SV Talk, Tuning & Tweaking 15 16-07-07 08:56 AM
running in new sv caines SV Talk, Tuning & Tweaking 9 06-12-04 10:51 PM
Is my SV650 running lean? trailer_parks SV Talk, Tuning & Tweaking 5 22-11-04 01:53 PM
