Old 25-09-06, 09:17 PM   #21
RandyO
by the time you avoid all the sensitive areas
radiator fins (pressure washer will bend fins)
bearing seals & brakes (pressure washer will blow water past seals)
chain (pressure washer will blast water past o-rings)
anything electrical
you might's well wash it by hand
Old 25-09-06, 09:23 PM   #22
jet washing a bike is a SIN! and if it doesnt take 6hours your not doing it right.
Old 26-09-06, 07:49 AM   #23
andy
anything electrical
Exactly, and dont forget to add stickers to that list!
Old 26-09-06, 07:58 AM   #24
hovis
jet wash for sale
Old 26-09-06, 10:12 AM   #25
tricky
Originally Posted by andy
After seeing the damage jet washes have done to dirt bikes over the years I would never use one again unless I had to
It was always the dirt bike riding rather than the jetwashishing that damaged my dirtbikes
Seriously though if your carefull with the jetwash you should be ok.
I do mine regularly with one without any problems.
Careful is the key - keep it well away from all bearings including the chain. I have seen so many bearings that have had all the grease blown out of them and got corroded beyond repair. Sure dirt riding is not good on the bearings either, but the only way the grease gets out of bearings is with jet washers......
I've never broken a clutch or a front brake lever with the jetwash
I did once strip part of the lettering off of a brand new, very expensive, Fantic fuel tank with one once though
Old 26-09-06, 12:04 PM   #26
timwilky
timwilky's Avatar
Ok, I know this is a little late in the debate but :-
Why take the bike out the garage if it is going to get dirty?.
opening the garage door is enough to destroy the controlled humidity and dust filtered environment I keep my bike in. God riding it would get it into a disgusting state.
Not Grumpy, opinionated.
Washing Bike Jacket Inner Fleeces 5v5 rider Bikes - Talk & Issues 2 23-02-08 09:47 PM
car/bike wash hovis South & West Surfers 3 28-04-07 04:55 PM
how often do you wash your bike? hovis SV Talk, Tuning & Tweaking 16 20-02-07 04:34 PM
Any one wanna wash my bike diamond Photos 20 09-02-06 03:29 PM
washing my bike? flash car wash system. hutchy SV Talk, Tuning & Tweaking 7 16-06-05 12:33 AM
