Old 05-01-07, 11:49 PM   #21
SV Ste
Hi hovi & gang
I made my own, took about two hours, but i did have a selection of cutting discs and die grinders at my disposal. This was made from a sheet about 3-4 mm thick. Used the existing footpeg and hanger as the guide.
http://forums.sv650.org/viewtopic.ph...ghlight=hanger
was a mess about at first, but looking at the one with the cut off foot peg, that lokks awesome. gonna do that with mine next job.
Have fun.
Old 06-01-07, 09:56 AM   #22
hovis
Originally Posted by SV Ste
Hi hovi & gang
Have fun.
dont surpose you have a template
Old 06-01-07, 10:06 AM   #23
Dysparunia
Originally Posted by carlos
Kwak, the cleanliness of your bikes never cease to amaze me
Hmm, this has been discussed before. Note how all the pics look to be in the middle of a bright & sunny day with lots of flowers out. Not too many of those recently.
Tis an old picture I tell you, bet just after he bought it. Go on, show us a picture from today.
Not that I'm jealous or nothing......
Old 06-01-07, 10:30 AM   #24
it was taken not long after i got her but if anything its cleaner now i havent rode her for weeks because of the ****e weather
Old 06-01-07, 03:08 PM   #25
SV Ste
hovi, i didnt make a template but one is easy to make.
I made mine by cutting the shape very roughly, drilling the two holes for the subframe bolts then bend the first angle away from the bike (on the bench not on the bike!) this the allows the second bend to be done and the basic shape is complete. Then mark and drill the exhaust bolt hole. Finally cut out the shape of hanger that you would like. All this was done around the footpeg.
As long as the two subframe bolt holes and the exhaust bolt hole are in the same postion as the footpeg ones then what you do in the middle is entirely up to you.
Use some thick card as a template if your not sure, then use some wire (coat hanger) attached to the back of the card with gaffa tape bent to the correct angles this will make your template. Remove the wire flatten the card and transfer onto a sheet of stainless or ally. then cut out shape, drill holes and finally bend the angles (I done mine in a vice). Hey presto. This is the best way if your using a jigsaw to cut out the shape.
Hope it helps
Old 06-01-07, 04:45 PM   #26
hovis
thanx..........
Old 18-01-07, 12:43 PM   #27
hovis
just fitted my new hanger off fox7 (thank you)
as you can see i made a cover so you cant see the bracket with a hole in.......which is nice
i am happy
Old 18-01-07, 02:06 PM   #28
That's a nice touch Hovis, tidies it up no end...
Old 18-01-07, 02:26 PM   #29
dirtydog
Knob faced knobster
dirtydog's Avatar
Originally Posted by hovi5
i dont like the 2 bits of tube welded together look............. im after a flat bit of shiny metal look
2011 Speed Triple 1050
Old 18-01-07, 02:30 PM   #30
hovis
but it was a bargin
& i quite like it now
Edit yourself across the Gap suzsv650 Idle Banter 5 16-02-09 03:49 PM
flame graffix (with picy) hovis SV Talk, Tuning & Tweaking 24 31-10-06 11:27 AM
<edit> Open discussion on Garmin Quest </edit> biketeacherdave Bikes - Talk & Issues 5 22-01-06 11:18 PM
