Old 28-02-07, 02:19 PM   #21
Luckypants
Luckypants's Avatar
Default Re: Strange handling - help needed!
Read this The main SV650 site is a mine of info. Low tyre pressures will cause a bit of squirm. The tyre does not maintain it's profile while being leaned over and so feels odd.
Originally Posted by Mogs View Post
Way too high Hovi5, I'm on Azaro's and use 34/36, that high and you will be taking too much rubber off the road.
From the Avon website 36 front, 42 rear.
Old 28-02-07, 02:21 PM   #22
I think Avon actually recommend higher pressures, because of their funky carcass design?
Old 28-02-07, 02:54 PM   #23
Mogs
Mmmm, thanks for the correction bad advice is worse than none, those were the pressures as recommended by the fitter, he's normally very good, he wrote them on his card, I just checked. I've been riding at these pressures since early Jan with no probs.
Mike I looked at the website, its quoting for Storms, I'm on the older Azaro's, I can't find a reference to them. Now I'm concerned.
Old 28-02-07, 03:09 PM   #24
hovis
Originally Posted by hovi5 View Post
try 36- 42 ?
Ignore this probably got it wrong
applogie accepted
Old 28-02-07, 04:26 PM   #25
Luckypants
Luckypants's Avatar
Avon have standardised on those pressures, read the link I posted to the main site FAQ. AV35/36 (original Azaro with curvey tread) AV45/46 (Azaro II) which I think you have and are what I have and the AV55/56 (Storm) use the same pressure.
HTH
Old 01-03-07, 07:51 AM   #26
Mogs
HTH
Mike your absolutely right, this is what the Technical boffin at Avon Had to say, I take everything back that I thought about my tyre fitter.
Sent: 28 February 2007 17:00
To: Morgan, Kevin
Subject: RE: Tyre pressure
Hi Kevin,
You will get more mileage out of the tyres with 36/42 psi in them. If you use 34/36 psi, the tyres may warm up slightly faster and grip slightly better but with increased wear. I don't think this bike is so sensitive to pressure changes as most are. In these cold conditions, dropping to 34/36 psi is probably a good idea.
Best regards,
Peter J McNally
M/C Technical Product Manager
www.avonmotorcycle.com
Sent: 28 February 2007 15:34
To: McNally, Pete J.
Subject: Tyre pressure
After a visit to your factory last year. You were successful in persuading me to change from my former Bridgestone BT020’s. My bike 2003 Suzuki SV 650s k3, now has Azaro ST AV45/46 fitted. I wanted the Storms AV55/56, however at the time none of the local supplier/fitters were able to source them and things were pretty desperate.
The fitter recommended that the pressure be 34/36 psi front/rear. Recently I’ve been having a conversation with friends and they have pointed out that you recommend 36/42psi respectively.
Obviously, I tried to check, your website does refer to the Azaros but when checking on pressures does not list them, only the Storms/ Viper Sport / Viper Super Sport.
I’ve not noticed any handling problems, but I realise if I’m running at too low a pressure my tyres can’t be performing at their best and won’t last as long as they might.
Can you give me a definitive answer.
Thanks
Kevin Morgan
Old 01-03-07, 08:17 AM   #27
mattyL
For what its worth, I am using the Avon Storms and was running 34psi Front and 37psi Rear. Changed to 36/42 last night as someone recommended and it definitely feels better in the turns, so I'm gonna stick with these pressures.
P.s. if anyone has an unused/low miles OE SV650 rear shock I would be interested in buying it off you, my shock is officially very dead!
Old 01-03-07, 08:47 AM   #28
andyb
Not sure whether you got my PM matty but I have a ZX shock going with only 3500 miles on it.
Old 01-03-07, 09:22 AM   #29
mattyL
Ah just replied to you Andy
Old 01-03-07, 11:57 AM   #30
Luckypants
Luckypants's Avatar
Very useful Kevin, thanks for letting us all know.
Strange handling. stevie16v Bikes - Talk & Issues 19 26-03-09 05:07 PM
What does Handling mean? Stu Bikes - Talk & Issues 22 17-01-09 10:49 PM
Handling. Lozzo SV Talk, Tuning & Tweaking 62 02-09-07 05:41 PM
sv handling mic-hull SV Talk, Tuning & Tweaking 8 29-06-07 09:26 AM
Handling a 1000 v 600 Kevin Bikes - Talk & Issues 8 24-02-05 07:10 PM
