#21 |
If you was riding though the junction and staring at the camera and you didn't see it flash twice then you are probably going to be fine.
Ch00
#22 |
the camera was bhind me.and it was sunny. do they even flash?
#23 |
Yep same as the old Gatsos
#24 |
There's supposed to be a 2-second delay between red and the camera being activated so you should be OK.
I've gone through reds with cameras up to a second after the red and had no problems so I assume that's true. There's also meant to be a speed limit below which the camera will not work (to allow for the fact that you could have gone through the light legitimately and then been stuck in traffic while the light turned red) but I don't know what it was meant to be - probably around the 10mph mark. Never knowingly been in a situation where I could try that one out though - if I can get through the lights on the bike by the time they're red then I'm long gone by the time the camera would kick in. |
#25 |
I belive its the case that if you are even partially over the white line when the lights change to RED, you are ok to continue (Its an offence to stop with your wheel over the line remember)... If you where going at a speed that would have "left you in the middle of the junction" you where more than likely to be over the line, even if only a bit, when the lights changed... Unless you where going some. I wouldnt worry too much..............
Me being a numpty - no neutral light and fi light is on | Whitehouse | SV Talk, Tuning & Tweaking | 8 | 03-04-09 03:50 PM |
2 blown brakes light bulb's and a parking light. | Grinch | SV Talk, Tuning & Tweaking | 4 | 20-10-08 11:08 AM |
gas light?(that'll be fuel warning light) | Spanish Fly | SV Talk, Tuning & Tweaking | 9 | 08-06-07 05:45 PM |
clear tail light / stop light Lens for sale | SVTONYB | For Sale - SV's and SV related items | 7 | 20-05-07 04:55 PM |
sv650 99-02 rear light+indicators+numberplate light | andyrs | For Sale - SV's and SV related items | 3 | 29-09-06 10:59 AM |
