Old 11-06-07, 07:28 PM   #21
andyaikido
Default Re: To all you knee down experts
Kwak, is your front tyre worn to the edge too?
On my CBR (same tyre sizes I think) the rear will wear to the edge while leaving an unused strip of about 10mm on the front so there is more lean to be used. Probably got something to do with the way the tyre deforms.
About the kneedown i'll say what I always say: hang off as far as you can. If it feels ridiculous it's probably about right.
Oh, and the road probably isn't the place to learn to do this. Get yourself on a trackday!
Old 11-06-07, 07:46 PM   #22
jay boi
i saw a video of this bloke showing proper position and the lot. it helped alot. thes a video on youtube. its a mcn teacher showing this bloke how to do it. type in knee down n ull get it.
the way i got mine down was:
slide a cheek of the seat. ull feel the seat inbetween ya crack.
keep ya arms relaxed, if ya on a right hander, keep ya right arm bent and ur left arm restin on the tanks the best position.
just let ya leg drop in with a lil bit of perswation. dnt force it dow.
and try and hold youself with ur outside leg (the 1 that aint gonna be on the floor)
just stay relaxed n ull b fine
hope it helps.
jay
Old 12-06-07, 08:42 PM   #23
ive got about 10mm of front tyre left.
Old 12-06-07, 09:11 PM   #24
andyaikido
There's more lean to be had then. Get to the point you were at in the first post and nudge the inside bar.
(not my fault if you crash)
Old 12-06-07, 09:16 PM   #25
Steve_God
I was in a similar position when I started until I had some assistance from a few mates watching me.
I was getting the bike position and speed fine, but no knee down...
It was due to the position of the knee itself.
Make sure you stick it out, and then down - that's the important bit.
Takes AGES to do it at first, but you almost feel like you're forcing your knee down into a foam mat from where you are positioned already.
You'll get there!
Old 12-06-07, 09:31 PM   #26
i need a mini moto to practice on.
Old 12-06-07, 09:36 PM   #27
sinbad
I've often wondered about this. Is it faster on typical British B-roads to
A: Ride flat out, full tilt, hanging off, knee down, but compromise the optimal line in order to avoid head in traffic/head in bush syndrome.
or B: Ride the bike more upright, don't hang off, but take a smoother arc, using a bit more road, and making the corner less sharp.
Probably the former, and depends on the particular corner I'm sure, but I reckon there's not much in it.
In any case, kneedown is a roundabout only affair for me, not that I do it any more.
Old 12-06-07, 10:21 PM   #28
Lozzo
Originally Posted by 1RichSV650 View Post
I duno how to do it but reading this you should hang off like a monkey, one buttock cheek left on the seat is best
http://www.champ.org.uk/bikes/kneedown.htm
Where on earth did you dig Champ's knee-down link from. Neal's a close mate of mine, he'll be tickled that his kneedown guide is being touted around here.
Old 12-06-07, 10:23 PM   #29
Lozzo
Originally Posted by HooliganDan View Post
Excellent tyres, they really inspire confidence. One last thing as someone else said is on thw inside leg of the turn (so right leg for right turn) use the ball of your toe on the peg and it helps push your body away from the bike. Just don't go too far and push yourself off though eh!?
I run my Daytona on Pilot Road2 2CTs, good enough for regular knee down with confidence on normal roads. The Pilot Sports are even stickier.
Old 13-06-07, 02:28 PM   #30
i dont think for on minuet the tyres are the problem its me that the problem.
Any PCI DSS experts on here? krhall Idle Banter 8 03-12-08 09:52 PM
Experts of the law? gettin2dizzy Idle Banter 11 17-08-08 03:46 PM
Diesel car experts? the_lone_wolf Idle Banter 45 30-07-08 12:42 PM
Any scottoiler experts? creamerybutter SV Talk, Tuning & Tweaking 5 17-06-06 09:50 AM
Any eBay experts? creamerybutter Idle Banter 10 14-06-06 09:49 AM
