#21 | |
![]() I used to quite happily access hotmail using Firefox on mandrake10 ![]() I also used Trillian for Yahoo/ICQ/MSN (all at the same time sometimes ![]() Pete |
#22 |
well you can on outlook but yeah u're right
so i'm just trying to use it less till I get rid of it |
#23 |
#24 |
Ubuntu here to. I only dual boot as I like to play alot of games which are not generally linux compatible.
I also dual boot at work as I am trialling Ubuntu for a work environment OS. If games ran in linux (i know about Wine but its not really practical) then I probable woudlnt have had windows for years now. |
#25 |
Baph - as always - pls explain
#26 |
Hasn't anyone tried VMWare? Too expensive perhaps?
WinE used to be known by the longer name of "Windows Emulator" until uncle Bill threatened to sue IIRC. Now "Wine" is a recursive acronym meaning "Wine Is Not an Emulator" and is the name of the project that allows you to execute programs originally written to run on M$ Windows under Linux. The difference between Wine and VMWare is that wine creates an "environment" in which to execute a program. No windows license required. VMWare on the other hand creates a "virtual machine" and hence requires a license for each virtual machine OS used (unless you use Linux on all those virtual machines :P). I last used VMWare a few years back, but it seemed pretty neat ... you could "switch" between machines at the click of a button ![]() Pete |
#27 |
Pretty much as Pedro68 said. Except he missed pointing you to their website. http://www.winehq.org/
Basically, run WinE, and you can run Windows applications, under Linux. Essentially all it does is map the Windows API to the corresponding functions under Linux. Works well so it does. I've even see Half Life 2 (windows "required") running under WinE. On the same (dual boot) machine, it ran with a higher FPS in WinE than it did in Windows. Last time I used it, it was a bit of a pain trying to configure different applications to run right though. But a little playing around, and you're good to go. From memory, you can even configure a Launcher (shortcut) to fire a given app under WinE straight away. For those thinking about VMWare, check out Xen instead. ![]() |
#28 | |
Not Grumpy, opinionated. |
#29 |
I shall give it a try - have seen refs to it before but never tried it
#30 | |
Resize HDD on Vista - Help? | 600+ | Idle Banter | 8 | 29-03-09 08:42 AM |
xp vs vista | stewie | Idle Banter | 57 | 03-12-08 02:45 PM |
Vista look on XP | Blue_SV650S | Idle Banter | 6 | 13-07-08 11:18 AM |
Vista - Waheyyyyy! | plowsie | Idle Banter | 97 | 14-04-08 04:50 PM |
Vista....arrggghhhh | dizzyblonde | Idle Banter | 34 | 19-07-07 11:03 AM |
