#21 |
#22 |
Agreed! Thanks for the pics, I've fitted mine now and I think I'm gonna stick with black as it seems to blend in with all the other black bits around it.
#23 |
I fitted a Pyramid hugger to my K6 about 12 months ago.
It took an age to get sitting straight, but all I did was man-handle it into position - not very helpful I know! The problem is with the metal bracket on the caliper side. Its a terrible design. The have easy access to a tapped hole on the top surface of the swing arm (where the rear brake hose was secured) and they chose to use a clamp type bracket that relies on pressure to keep it located. Crap design...and the rubber pads slide out from underneath the bracket too. I almost went to a local fabrication company I know to make me a bracket that would locate on the tapped hole. |
#24 | |
![]() As you have had your fitted a while, does yours pick up stones and other crap and drag it thru the hugger? Just worried if it was anything sharp, it could slice the tyre!! ![]() |
#25 |
I do pick up stones but I havent had any problems with them getting stuck that I am aware of.
#26 | |
![]() ![]() Quote:
When riding slow, like pulling off the driveway, i noticed a few noises. So I stopped to take a look. Sure enough, stones! Theres probably about 3mm gap between the top of the tyre and hugger. I'm sure it won't be a problem once they've squared off! ![]() ![]() |
I can't fit my Pyramid hugger right. | newts924 | SV Talk, Tuning & Tweaking | 18 | 09-12-08 08:18 AM |
pyramid plastics hugger | maff | Photos | 28 | 15-11-08 04:42 PM |
Pyramid hugger K3 | Rog | SV Talk, Tuning & Tweaking | 2 | 18-12-05 09:35 PM |
Pyramid Hugger 99 s curvy | philb | SV Talk, Tuning & Tweaking | 3 | 11-07-05 08:16 PM |
Fitting a Pyramid Hugger | enginedriver | SV Talk, Tuning & Tweaking | 15 | 05-07-05 01:41 PM |
