Old 10-09-07, 03:56 PM   #21
SV650Racer
Default Re: Oil Drain Plug seized and rounded
As the SV technically hasnt got a seperate sump do be careful not to do anything that may crack the cases. If you do then its new crankcases time or a welding job will will require a complete engine strip.
Halfords do a tool that is specifically for fitting rounded off bolts. If you use an impact wrench dont wollop it as it could cause the cases to crack.
Old 10-09-07, 04:15 PM   #22
TSM
The Sick Man
TSM's Avatar
pipe wrench seemed to do the trick on Jester666 sump plug which was rounded, it just grips harder and harder as its tightened up.
Air Cleaner Drain Plug phizog SV Talk, Tuning & Tweaking 11 30-12-07 07:36 PM
Coolant drain plug failure petevtwin650 SV Talk, Tuning & Tweaking 3 19-02-07 11:13 AM
rounded off sump plug - removal, how? will Idle Banter 8 17-03-06 05:20 PM
where is the coolant drain plug?? hall13uk SV Talk, Tuning & Tweaking 34 25-05-05 04:25 PM
Oil drain plug- Help. Peter Henry SV Talk, Tuning & Tweaking 7 17-10-04 01:26 PM
