#21 | |
Matt |
#22 |
If you think there is still some air in there, try old 'zip tie the brake lever back to the bar overnight' trick. Helps to banish lingering air bubbles.
#23 | |
Matt |
#24 |
Hard as you can...
#25 |
#26 |
You can get a reasonable lever with std lines.
There's something else going on, either calipers need rebuilding, carriers bent, discs bellowed or pattern lever. Have you got the air out of the 'back' of the master cyl? if you flick the lever whilst squeezing the reservoir tube, if youve emptied the master there will be air here, this bit effects the initial takeup of the lever |
#27 |
Test the condition of your rubber hoses by getting someone to pull on the front brake as hard as they can and then examine the lengths of the hose to see if there is any obvious 'bulbing'. If there is then your hose is knackered.
#28 |
I got a set of Goodridge braided lines on ebay for £40 back and front. The only thing I'm not sure about, is the front is from the pedal to the caliper, what about from the pedal to the resevoir? Doesn't that need to be braided too for consistancy?
#29 |
Hi Mike, I presume you mean lever when you say pedal?
For a reason I don't know the resevoir pipe is ok standard, because it's not part of the braking process I guess. Have you got the two line front set-up? IE: both lines go straight from the master cylinder. |
#30 |
The reservoir is not pressurised and feeds fluid into the system by gravity.
braided hoses | loneranger | SV Talk, Tuning & Tweaking | 0 | 29-10-07 08:38 PM |
braided hoses | hovis | SV Talk, Tuning & Tweaking | 11 | 18-11-06 11:04 PM |
braided hoses | hovis | SV Talk, Tuning & Tweaking | 9 | 15-11-06 07:03 PM |
Braided Hoses (again) | tricky | SV Talk, Tuning & Tweaking | 6 | 04-03-06 10:25 PM |
HEL Braided hoses | tricky | SV Talk, Tuning & Tweaking | 14 | 20-02-06 10:06 AM |
