Old 30-03-17, 06:00 PM   #3081
Kenzie
Kenzie's Avatar
I like that one, are you going to bid? I have unloaded the Perkeo and transferred the film over to the Yashica-Mat.
Old 30-03-17, 06:14 PM   #3082
johnnyrod
johnnyrod's Avatar
Not sure, there is another one starting at £15 with one bid but also extras, ends Sunday, in Derby. I emailed them and they've confirmed the struts and shutter are fine - most sellers don't bother to update their ads with good info.
Apparently the problem with Epsilon shutters is that the cokking lever, I think when it returns, whacks teh escapement body and eventually distorts it, so problems starting with sticking slow speeds and eventually it jams. The 99p one above says sticking so could be more than just a clean-up job. Read nothing but good things about the Xpres lens though. Will try to snipe it.
Old 30-03-17, 07:49 PM   #3083
Kenzie
Kenzie's Avatar
182501715118
Old 30-03-17, 07:49 PM   #3084
yokohama
Kenzie, if you can find something in your screw collection, I need one to go through a hole of about 1.5mm. screw or tiny bolt would do, maybe around 5mm long.
If you ever get your hands on a 35 RC, don't even think about removing the screw that holds the battery contact.
Old 30-03-17, 07:56 PM   #3085
johnnyrod
johnnyrod's Avatar
My God there are some rough ones around! I think a triplet like a Novar is fine for up to 6x6 but 6x9 is so big that you get a lot of vignetting in the corners without something a bit fancier like a Tessar. I think that's also the reason a lot of the triplets on 6x9 are f6.3 or slower, you'd get nothing useful if you could put them wider.
Old 30-03-17, 08:15 PM   #3086
Kenzie
Kenzie's Avatar
Yoko, will see what I can find. Johnny, how about the Voigtlander then?
272604874473
162442456819
Old 30-03-17, 08:47 PM   #3087
johnnyrod
johnnyrod's Avatar
Second one has a Helomar lens which is a cheap triplet. Had seen the first and thought it was a 6x6 but is actually 6x9. Not sure which lens it has
Old 31-03-17, 06:06 AM   #3088
Kenzie
Kenzie's Avatar
My Duo 620 from Rocky is on the way. I had completely forgotten about it. Did anyone else grab anything from Rocky? Yoko, where did you send the T50? I forgot to say I changed stores, its not a problem though.
Old 31-03-17, 07:08 AM   #3089
johnnyrod
johnnyrod's Avatar
Nah, I'd really only trust his stuff in the flesh I think, but if work takes me down that way I'll stop by and kick the tyres
Old 31-03-17, 07:45 AM   #3090
yokohama
Ah, I sent the T50 to the usual address, sorry. Didn't know you'd changed. It should arrive today maybe.
I ordered a Helios from Rocky - expecting that soon too.
