Old 13-03-15, 06:36 PM   #381
Default Re: What have you tinkered with today?
Make sure there's no powdercoat residue left in the threads it's the best threadlock known to mankind.
And as Admin has said,
Old 13-03-15, 06:38 PM   #382
Sorry bit slow here, trying to type on a bus with a wanna be Lewis Hamilton at the wheel.
Old 13-03-15, 07:03 PM   #383
Re tap the threads as it won't affect the performance
Old 13-03-15, 07:20 PM   #384
admin
John T
admin's Avatar
Yes the tap will just clean out the threads. No need to touch the metal.
Old 14-03-15, 09:32 AM   #385
NTECUK
NTECUK's Avatar
If you are mounting components metal to metal your not going to get the same torque with the pliable powder coating.
Old 22-03-15, 08:04 PM   #386
BeMA
Took my SV off its stands. The upgraded front end and overhauled brakes felt good on a tiny run out! I even managed to paint the exhaust (using stove paint so that I didn't have to remove it again) and fitted some foot peg riser plates. Rear brake is to overhaul next, then sort out the fairing.
Old 22-03-15, 09:04 PM   #387
garynortheast
garynortheast's Avatar
Spent all afternoon swapping the European headlight unit on my curvy for a British one. Gave me the chance to tidy up a couple of small odds and ends while I was at it. Got it all back together again and discovered the front brake light switch is playing up and the large block connector behind the top fairing is a bit intermittent, causing the headlights to come on in random fashion when I switch them on. Grrrr! Back off with the fairings again tomorrow to sort it out.
Still, at least it'll give me the chance to reconnect the sidelight which I forgot to do when I was putting it all back together this evening.
Old 23-03-15, 10:34 AM   #388
swaffle
I know this was yesterday but it was far too sunny to be indoors telling you about my tinkering at the time.... fit my viper carbon to my K1 yesterday... purrrs allot happier now
Old 23-03-15, 11:02 AM   #389
SvNewbie
Fitted one of Bibio's gadgets to wire in my GPS, easy to fit and does exactly what it says on the tin. Hardest part was figuring out how to route the GPS cable up to the front of the bike.
Then spent a couple of hours trying to get the PoS Chinese bike my friend bought last year to start.
Old 23-03-15, 11:45 AM   #390
jambo
jambo's Avatar
Yesterday was spent trying to fit 2 sets of race bodywork to 2 Sv650 race bikes.
Bearing in mind the fairings were specific to the SV650 99-02, the fit was not what you'd expect. Many, many hours and I was only assisting. What a pain in the backside, should have just fitted a belly pan and front number board.
Jambo
Been got already today.. 454697819 Idle Banter 16 01-04-10 02:08 PM
Today DaveP The Border Patrol 4 02-03-10 10:52 AM
Going out today? tj2 The Border Patrol 1 01-06-09 09:22 PM
Today Tara Guildford Massive 14 02-06-08 11:56 AM
Today...... Caddy2000 Idle Banter 15 19-04-06 05:39 PM
