#31 |
Wait until the temp gage spits out a figure before I ride it (I think 20-23 degrees C), don't use too many revs until 40 degrees or so and wont cane it or accelerate hard until it is up around the 70-80 degrees C.
Regards
Phil I'm not here for a long time, I'm here for a good time! Blue SV650 K3, GSX-R K5 front end, TL1000S clip-ons, lower fairings, seat cowl, gel seat, Pyramid undertray, R&G crash bungs, stainless steel bar ends, full titanium Akrapovic exhaust, Power Commander, clear rear light, flush mount front indys, mini rear indys, Autocom 300 duo intercom, Acumen cat 1 alarm and Micheline Pilot Power 2ct's. |
#32 |
Cheers Ralph, i'll keep an eye out for one!
#33 |
On most carb bikes they say around 40-1min of full choke and then easy off to no choke before getting the revs above 6k.
I think you need to have one of these things atleast once and you'll know all about them when or if you buy a carbed bike. E.g if you never ride in the snow and one day get cought out in the snow you'll s*it yourself becasue you won't know how to handle the situation. (<- if that makes sense) If I were to buy a FI bike I'd still let it idle for about 40-1min just to let the oil sink and circulate before riding. TBH, if you can afford the Bike, Insurance + Tax I'm pretty sure you can afford to lose 40p(Max) in fuel. |
#34 |
It's not about the fuel, it's about the best way to warm it up... which is by riding it gently. Only stand there warming it up until it will tick over by itself.
#35 | |
Also, with the FI bike i'm sure you don't get a choke so either way id still let it idle for around 40-1min just so all the oil is running. |
#36 |
#37 | |
Well if you think about what the "choke" on SV does (I'm guessing you don't know), it richens the mixture and opens a small passageway to let a little more air in. Whereas an FI bike, obviously has no choke. It has a map which says it must add more fuel when cold, and operates the secondary throttle valve to press a lever on the main throttle cam to let more air in. The upshot being a faster, rich idle. Sound familiar?
#38 | |||
Also your wrong, it doesn't allow more air to get in it reduces the air flow allowing more fuel to be burnt, thus making the engine fire quicker than usuall. ("Cold start") Quote:
(I'm not trying to sound arsy atall, just your putting it across to me asif you think I don't know, yet you don't know me atall, or anything on my biking knowlage for that matter. Ok I might be slightly exaggerating on the 40seconds, but it states in the manual " Allow suffucuent idling time after cold engine start to allow lubricating oil to reach all critical engine components" 'To me' thats more than 20seconds, Yes 40 seconds may be abit too much. Last edited by AZZ3R; 08-10-11 at 09:39 PM. |
#39 | |
FI has no choke either, it has a fast idle and idle enrichment, which does exactly the same thing as the carb un. How exactly would reducing air flow allow more fuel to be burnt?
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 09-10-11 at 05:09 PM. |
#40 |
I think we need a shovel.
Warming Up! | Crazy Dave | Bikes - Talk & Issues | 5 | 20-04-10 04:27 PM |
Global warming | hovis | Idle Banter | 30 | 13-07-08 11:19 AM |
Warming up tyres | Warthog | Bikes - Talk & Issues | 10 | 23-11-07 08:35 AM |
Warming up | Alpinestarhero | SV Talk, Tuning & Tweaking | 24 | 10-01-07 08:15 PM |
Global Warming | linco | Idle Banter | 50 | 04-11-06 07:17 PM |
