Old 12-03-08, 09:22 PM   #31
hlaf_lyfe
Default Re: curvy throttle
thought i might as well sort it out while its off the road...
Old 12-03-08, 09:24 PM   #32
hlaf_lyfe
ta will lube it and if that doesnt workjust give up.
Help much appreciated.
Old 12-03-08, 09:25 PM   #33
well even if its off the road, you still won't be able to tell if your playing around with throttle is going to change owt. A big factor of the response is to have an engine there in the first place
Old 12-03-08, 09:26 PM   #34
Lol, no.
OP was about it being stiff, rather than the actual engine.
If it's an engine problem then a good service usually helps.
Old 12-03-08, 09:28 PM   #35
I thought the young man blew up his engine with oil starvation???
r6 throttle mod , can it be done on a curvy? gaz-sv650s SV Talk, Tuning & Tweaking 45 16-02-10 05:01 PM
Curvy - Plastic Casing round the Throttle? JamesMio Stuff Wanted 7 19-12-08 12:32 PM
2002 curvy throttle problems Nicky S SV Talk, Tuning & Tweaking 8 31-08-08 10:02 PM
Other throttle cables to fit curvy SV ? Stig SV Talk, Tuning & Tweaking 0 19-01-08 01:34 PM
Throttle Tube (curvy) jakeblues68 Stuff Wanted 1 24-04-06 09:41 AM
