#31 |
Water will sit in the filler cap and go in the tank as soon as you open it or go down the filler neck by seeping past the seal on the moving part of the cap.
Hope the drain screws on your carbs work ![]()
#32 |
thats why i was going to put a bead of silicon around the filler cap before i put it back on to stop any water getting under it.
will that not be suffice? |
#33 |
No because the cap and the ring under it aren't a perfect seal. Why do you think people get water issues when the drain gets blocked?
A capful of meths in the fuel every now and again might sort it when it starts to misbehave. (meths will mix with water and burn off)
#34 |
ahh right ok...
well im off back to uni tomorrow so wont be doing anything for a couple of weeks now till exams are finished! i will try feeding some hose through first like you suggested but if i cant get it through then blocking it may be my only solution untill i can afford a new tank! cheers for your help! will let you no how it goes when i tackle it in a few weeks! |
#35 |
Yeah, then again might be fine. A friend of mine had a bandit with a knackered fuel cap. Half a cup of meths per tank allowed it to carry on running
#36 |
http://forums.sv650.org/showthread.p...94#post1528894
See that thread for what happens when the vent tubes blocked...
#37 |
Sorry to be negative, but you need another tank.
Having seen this problem several times I know from trying everything suggested here and far more that short of opening the tank up, (that is; cutting the bottom out of it, replacing the tube and welding it back up), you'll never fix it, and you can't just block the drain - it's there for a good reason. This is a well trodden path, look here for some previous posts, and those are just mine - plenty on this subject on this forum.
#38 |
the good reason being to drain away the water? (correct me if I'm wrong)
so surly if i stop that good reason being there (IE stop water getting under the filler cap) then the drain is no longer needed? OR... as Chris has suggested putting a new pipe inside the old one. if i can get that pipe in why wouldn't it work? I'm not disregarding what you are saying you may be correct that there is no 'fix' I'm just trying to find a solution before having to replace the tank. any help / input is welcomed. |
#39 |
Knob faced knobster
I don't think it's possible to make the petrol cap completely water tight surely if you did it would cause a vacuum in the tank?
I would trust the Squid with what he's saying as he does know his stuff
2011 Speed Triple 1050 |
#40 |
Yup I would agree. Don't see why you can't run a tube inside the original drain though. What problems did you run into oh squidly one?
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 04-06-08 at 10:12 AM. |
black SV650s 2002 tank | mattglavin | For Sale - SV's and SV related items | 11 | 29-04-09 01:36 PM |
Fuel tank | svrich | Stuff Wanted | 4 | 30-09-08 07:45 AM |
2002 sv650s K&N problem | erics02 | SV Talk, Tuning & Tweaking | 6 | 18-10-07 09:52 PM |
blk tank cover, service manual, fork seals for 2002 | kingjoe | For Sale - SV's and SV related items | 0 | 20-04-07 05:14 AM |
need fuel tank for '99 SV - will a used one be ok? | FreshAL | SV Talk, Tuning & Tweaking | 7 | 08-03-06 03:51 PM |
