#31 |
#32 |
To prove the point .. these are my ROAD chicken strips (ignore the puncture)
![]() Do I give a feck they are 3 miles wide????? .... no ... Why? ... coz I now know it is meaningless!! ![]() |
#33 |
Jesus, a thread about chicken strips has evolved into Muffles virginity, or lack of
![]() I have some huge chicken strips i need rid of. I regularly keep my pressures checked etc, so its nice to know the angles you can push to. |
#34 |
Over the week end (you may have read else where on here) I had a play with the suspension set-up. Basically before when I pushed the bike in the corners it wasn't stable (twitching a lot), when I put the power on the front felt like it was pushing wide and the back wasn't settling down at all.
So I added a little rebound dampening on the front as I came to realise the return was too fast and violent when returning from a compressed position. This helped a lot, fixed the front pushing wide issue but when I put the power on in the corner it was still not feeling right. So I added a little Dampening on the back shock (its a cheap one... only problem with the falco ![]() So basically play with the suspension make it suit you and you can ride so much faster if you want and so much smoother. Infact its made such a difference that the edge of the tyre (there is are numbers and tiny michelin on the michelins) is almost bare of the number markings and the little michelin man... after just 150 miles with the better settings. I had managed to get to the edge of the tyre before I did this but now it does it NO PROBLEM! ![]() So have fun and take care! |
#35 | ||
Yes you can get rid of your hoops on the road. You're on BT016s so this should be fairly easy on your Gixxer - they have an easy profile. It may be your riding style, tyre pressures, getting on the power earlier but please don't compromise your safety by trying to get rid of the last few mm. FWIW...I have 015s on my 600rr and got rid of the strips in the first 150 miles but this is due to the profile of the tyre.
Different tyres will exhibit different strips wear (road). I've have 015s with 0 strips rear, 3/4 inch strips front. On Diabolo Corsa IIIs - 10mm rear - 2-3 mm front. 2cts - 0 strips rear 3-4mm front - same bike same riding style. Quote:
IF YOU MUST drop pressures... only drop by 1 or 2 psi at a time and get used to riding with it for a while. If it feels better then you may be on the right track - if not then go back to std. Don't mess with the front pressures. Keep to the std - 34 or 36 psi on your bridgestones. I'd also get on the Gixxer forums - you'll get good advice there from people who know your bike. As good as the advice is on here it's limited for your bike. As an aside - I run 34-34 now but this is only after loads of riding and only small adjustments were made to get there. IMO there are far more important things than getting rid of chicken strips. Enjoy the ride dude. In time and experience they will disappear. |
#36 |
I was the same with my Dunlop D208. Couldn't get near the edge, but on the AM45/46 no strip at all.
Flickr: http://www.flickr.com/photos/croozenooze/ Facebook : https://www.facebook.com/colin.hughes.1213?ref=tn_tnmn Yoo Toob https://www.youtube.com/channel/UCjG...eMWUx4Ud2dK-yA |
#37 | |
![]() 27. Does it get more difficult with age or something? ![]() |
#38 | |
![]() OK so you reckon it is quite easy to get rid of them on the road? I'm not going to ride in a manner that I'm not comfortable with, but this is the question I had at the end of the day - is it something that is realistically possible or not (there'll always be a few that can get rid of them on the road, but in general...do people get rid of them on the road)? |
#39 |
The chicken strip thing is really just a load of willy waving!
![]() As Blue said, on the road its meaningless. Even on the track I didn't get right to the edge of the front Road Pilot 2CT. It all depends on the profie of the tyre. The rear was sha99ed though! |
#40 | |
Btw I thought he meant meaningless anywhere? I.e. doing it for the sake of doing it, on road or track, is (often) not conducive to fast riding? I haven't been ignoring my lines for example - I was practicing those before I was trying to get to the edge of the tyre - still wanna do it though ![]() |
Chicken strips | rictus01 | Bikes - Talk & Issues | 106 | 03-05-08 06:24 PM |
Chicken Strips 2... | Gordon B | Pennine Massive | 31 | 19-08-07 09:14 AM |
Chicken strips ? | oldjack | Bikes - Talk & Issues | 38 | 28-08-06 08:43 PM |
Chicken Strips | AccuracyInternational | SV Talk, Tuning & Tweaking | 13 | 20-02-05 07:39 PM |
Chicken Strips | Scoobs | Photos | 17 | 06-01-70 09:17 AM |
