#31 | |
Gixer rear shock is good improvement over stock. |
#32 |
http://forums.sv650.org/showthread.php?t=153847
That thread has Springs and Rear Shock for a total of £100 , which is about the right price , if you are gonna talk GSXR front ends then do a search on the forum for that as there a loads of threads about them . Personally I have done the front Springs with 15wt oil and the GSXR rear and I ride the heck out of my bike without any worries whatsoever .... a GSXR front end is an uneccessary extravagance in my humble opinion and a whole heap more expensive . |
#33 |
Cool - thanks lads - will price up some of the spring kits mentioned above and a k5 gsxr 1000 shock for a winter upgrade
![]() May use the other threads to look into the front end swap at a later stage with a separate thread ![]() |
#34 | |
#35 |
The real pain in the butt with it all is actually finding nice ones for sale in the first place , the rears are always around , the front stuff tends to appear when you have no money then vanish the moment you have the readies for it . I sat on the money for ages for a set of springs , had enough to buy new ones and was almost ordering some when somebody gave me the heads up on the forum over some used ones and from a rider of similar weight as well ..... result
#36 |
No waffle needed removing just that right anlge bit of plastic that is like a blanking plate oppisite to the tip over sensor when that shock was on my k3
#37 |
Will the GSXR1000K4 fit an SVK8, bearing in mind there was a slight model change post 04? If not which rear shock would be best for a K8?
Cheers Jim |
#38 |
Not sure if they're the same but I've got a K3 1000 Gixer shock on my SK8.
Do a search for shock table, you should get a list of shocks/sizes and spring rates. Last edited by Nobbylad; 04-07-10 at 07:05 AM. |
GSXR1000 K5/K6 Ohlins rear shock on a Pointy? | weecorey | SV Talk, Tuning & Tweaking | 24 | 29-01-09 08:05 PM |
GSXR1000 K5 Ohlins shock in a pointy? | weecorey | Mini-Twins | 1 | 27-01-09 01:22 PM |
GSXR1000 K4/5 rear shock ideal for a pointy sv | sv650k4 | For Sale - SV's and SV related items | 9 | 28-06-08 12:59 PM |
will a K3/K4 gsxr1000 shock fit a pointy? | sv650k4 | SV Talk, Tuning & Tweaking | 64 | 10-06-08 05:11 PM |
Help required fitting a GSXR1000 K6 shock | neio79 | SV Talk, Tuning & Tweaking | 5 | 10-09-07 07:04 PM |
