Old 09-09-08, 04:48 PM   #31
Sean_C
Default Re: Big bang R1
If everything goes to plan, and the job I've been promised at the local suzuki/yam dealer comes through, I may be able to get a sneaky test ride once it's in showrooms. Yeeha!
The only bad thing I see is that I've started browsing ebay for a cheap IL4 engine to fiddle with.......
Old 09-09-08, 05:04 PM   #32
ThEGr33k
Originally Posted by thor View Post
It sounds awful!
You dont like the sound of a twin (big bang) or a M1 (rossi's bike - a long bang). Id presume it will be a long bang like the M1, but I cant be sure. People often get the two mixed up, though I can see why, it does a similar job.
Originally Posted by gettin2dizzy View Post
You can rev it like a IL4 and you can optimise the burn better. It's all to do with surface area and accelerating mass.
I think you have some of it. It also has to do with air flow, more smaller cylinders are better than less bigger ones for high revs because the valves can occupy a bigger proportion of the area so allow more air into the cylinder.
Originally Posted by Dangerous Dave View Post
Yes, it should do but it all depends how the motor is set to run. I would think that this particular type of engine would rev high, after all it is the flagship sports bike.
- is this the design inspiration?
It will rev like a standard IL4 yes, it will make pretty much the same power, it should give greater traction and will sound better.
Old 09-09-08, 07:31 PM   #33
Sean_C
Hmmmm...
270º - 180º - 90º - 180º are the firing intervals. I'm only just learning about this, so please correct me as I'm sure you will need to.
A proper big bang engine would have ALL the cylinders firing close together, would it not? In which case.. what exactly is this?
Old 09-09-08, 08:11 PM   #34
You can rev it like a Il4 and you can optimise the burn better. It's all to do with surface area and accelerating mass.
Doesn't matter what order you fire them in you still have exactly same combustion chamber surface area and accelerating mass.
Surely to rev it, and to optimise burn you need short stroke and a hemi head. In whatever firing order.
Also, having all cylinders inducting at same time means far higher max flow through induction system and resulting increased reynolds numbers... more turbulence, more inlet vacuum. Also greater induction pulses, but that won't make much difference. The same arguement means the exhaust system will have to be far bigger in the collector to avoid back pressure which reduces top-end power.
I reckon in motoGP this makes a difference in terms of controlling a sliding tyre right on the limit of controllability. On the road I reckon it's a gimmick that will make sod all difference, oh except for massively increasing stress on crank, gearbox and driveline.
Old 09-09-08, 08:24 PM   #35
ThEGr33k
Originally Posted by Sean_C View Post
Hmmmm...
There are different types, (all the angles are crank shaft angles, not degree's between firing...)
V2 (90º SV) 90º/270º
V2 (60º Aprilia V990 engine - RSV etc) 60º/300º
Screamer = 180º/360º/540º/720º
Big Bang 2 = 180º x (2 pistons) / 720º x (2 pistons) http://www.youtube.com/watch?v=3gFhiQx9OmY
Big Bang 3 = 180º/360º (x 2 pistons)/720º (the one in my sig)
Suzuki V4 motogp bike = 0º/75º/360º/435º
Long bang (m1 - guess) = 0º/90º/180º/360º
All worked out by Performance bikes.
Hope this shed's some light on it all.
Old 09-09-08, 08:27 PM   #36
Sean_C
Thanks- I wish I knew more. I will know more
Old 09-09-08, 08:30 PM   #37
ThEGr33k
And like I already said making it sound a hell of a lot more interesting.
Old 09-09-08, 10:51 PM   #38
lukemillar
Originally Posted by neio79 View Post
hmmmmmm marginally, i bet this R1 is a fraction of a second faster to 60 and 100. Thats it. They are getting too small for normal sized people to ride.
Infact it could be argued its eaiser to increase the CC to acieve the same speed. My 6R is a lot lighter and smaller than the old 636 which his far more substantial in dimensions but only had 36cc more .Yet the older 636 is quicker where it counts. In some respects its a far beter road going bike than mine.
The weight thing isn't about straight line speed. It's all about corner speed and handling.
Old 10-09-08, 07:50 AM   #39
muffles
better ... bike than mine.
Just wanted to make sure that was well and truly captured, same as when ol' greeky says it!
Old 10-09-08, 09:08 AM   #40
STRAMASHER
STRAMASHER's Avatar
...........another manky Jap litre bike. What a surprise! Best of a bad lot.Emissions&catalyzer ******** ****ing up the designing of a nice exhaust system.
If I was a midget weekend warrior it would be:
New R1
GSX-R
CBR
ZX-10R
chitty chitty fecking bang bang hovis Idle Banter 35 03-01-09 12:33 PM
Bang! jumjum_0214 Bikes - Talk & Issues 25 23-07-08 08:19 PM
Bang! kwak zzr Idle Banter 9 05-11-07 11:03 PM
bang!!!! sv650nutter149 SV Talk, Tuning & Tweaking 18 15-08-07 07:14 PM
kill bill soundtrack bang bang hovis Idle Banter 8 22-05-07 03:53 PM
