#31 |
Yup, after annoying the neighbours by getting it to temp in the back garden, level has noticibly dropped to max. So cold overfill = ok at running temp. So i assume a fill to max at cold would actually be min required.
#32 |
Im well confused now as i said earlier i filled up ran engine as suggested in manual for 7 mins on idle then let it cool for 5 mins and on the paddock stand and when holding it level it showed jsut below the full line. so now in a state of panic i have left the office gone down to the car park and done my best to prop the bike up as level (under the side stand as i can) and the window is over full? this is driving me mad. is this because some of the oil will be sucked through the filter when running ?. also is there a decent way of measuring out 2.3 lites exactly to fill your oil tank?.
#33 | |
#34 |
PS, my bike has been dealer serviced last week with a full flush and oil change and matches exactly what you've just described.
#35 |
Thanks for the confirmation. just need to find out whats causing the hesitation when going up through the gears.
#36 |
OK so we've established motor has right oil level
![]() Try in 4th or something and just pin it from 2k or so right up to redline
#37 |
I will give it a go on the way home which is tricky in central london even getting into 3rd gear is a luxury! i must admit the problem, doesnt seem as bad in higher gears. do you think it will just fart out whatever is lodged so to speak
#38 |
You need to describe the problem better. Is it boggy or hesitating in parts of the rev range or is a problem actually shifting betwwen gears?
#39 |
yes its"hesitating in parts of the rev range"
#40 |
Which parts?
Can fork oil be topped up ?? | Stormspiel | SV Talk, Tuning & Tweaking | 6 | 20-06-05 03:01 PM |
