Old 14-01-09, 11:58 PM   #31
gettin2dizzy
Default Re: Two-up Euro-touring
Originally Posted by philbut View Post
I think he is refering to the ammo crates that I have welded to the side, as I believe he is considering making a similar set up. They are HEAVY. with the mounting frame they weigh just shy of 10kg or so each.
Somewhere in the specs for your bike will be the max load for the rear sub-frame. On my viffer there is a sticker under the seat Two up with loaded panniers is no problem.
BTW loaded panniers would be maybe 20KG - where does the 30KG for luggage come from?
As philbut said above! MASSIVE ammo crates, which weigh enough themselves. I'm sure I could load them up with 15kg each. Doing 2000 miles in a week or so with that much weight can't be good
Think I may need to investigate a new shock...
Old 15-01-09, 12:11 AM   #32
natcar
Maximum recommended pillion/luggage weight for the SV is higher than a lot of touring bikes, suspension is well set up for this. I found 200kg+ with pillion/luggage no problems (I do need to eat less cake)
Old 15-01-09, 12:13 AM   #33
Problem with using a taller shock is that it makes it a handful stationary. Sidestand leans over further too, so really makes you use your legs!
Touring on an SV jaffacakes Bikes - Talk & Issues 21 15-07-08 11:27 PM
The Euro Touring Season starts next week !! nigelporter EuroTour 0 13-03-08 08:35 AM
Euro Blue_SV650S Idle Banter 11 09-01-08 04:52 PM
Two up touring northdowns Bikes - Talk & Issues 13 14-03-07 11:24 AM
KBC Vr1 Euro thejewishone Helmets 2 27-05-04 09:28 AM
