#31 |
Im hoping ill have the bike for 2-3 years before I look again. Aside from sportsbikes, which im not looking to buy although I do find them very asthetically appealing, the Versys is one of the few bikes that ticks all the boxes. Like a standard SV, its nothing particularly special but hopefully a few bolt on bits will personalise it enough for me to want to hold onto it. I had the SV 3 years and only familiarity was making me want to change.
#32 |
About 3 months ago I bought a hornet with ABS. It has never kicked in yet and I hope it never does, but it's not about that. The best thing about it is that it gives you the confidence to brake solidly in any conditions, wet or dry. Get the ABS it's worth the cash.
#33 | |
#34 |
Yes, the same as ABS on cars. Although not something I've tested personally, the general consensus is that grabbing a fistful while cornering will have you off regardless of whether or not the bike has ABS fitted. There's an article in a recent PB on this. Not in itself a reason not to get ABS, I was just pointing out that ABS is not some magical braking panacea that removes the need for you to learn to brake properly (not that you were suggesting it was). Anyway, buy ABS or don't, it's your choice. Personally, I'm open to the idea on a tourer/commuter.
#35 |
ABS will stop lock up, not the front washing out.
#36 |
#37 |
When leant over? No it won't, the front can still be overloaded and slide, you can drop it that way without the wheel ever locking up.
#38 |
If your doing an emergency stop at high lean angles your pretty screwed i think... Unless you have run off. Moderate lean you could stand the bike up and lean yourself right off to make it go round the corner and try and stop it washing out. But tbh in a "Oh ****" moment your not going to be able to think of this and less likely to actually make it happen.
Best thing is to ride well within your ability to give yourself breathing space in a pinch... unless you are certain you can push it (great visability for example) ![]() |
#39 |
YC is right. When cornering you can overload a tyre's grip, causing a washout through braking without locking it up (which is what tells ABS to kick in) which is why ABS cannot protect against this.
#40 |
Kawasaki Versys. One of the lads that rides on same road as me has one of these. Go for a test ride first as they arn't very fast. They will be comfy though and they look pritty good.
How many bikes have you got? | Daimo | Bikes - Talk & Issues | 48 | 21-04-09 08:25 PM |
Sat nav for bikes | tinpants | Bikes - Talk & Issues | 31 | 17-09-06 09:04 PM |
You've got how many bikes?!!! | thor | Idle Banter | 17 | 04-05-06 09:14 AM |
New Bikes | Demonz | Bikes - Talk & Issues | 16 | 01-04-06 07:21 AM |
Sat nav for bikes | METZ | Idle Banter | 2 | 08-01-70 12:40 PM |
