#31 |
you have a threaded bit on the bottom of your camera and there is a bolt on the mount. I can't see how the mounts attached to the bike though lol. That clamp doesn't look sturdy enough.
It'd be easy enough to make one though if you've got a bit of rod and a tap and die kit. Altohugh I'm on a naked so might just strap my digi camera to the front of my clocks.
#32 | |
#33 |
I imagine the uclamp (probably worth lining with a bit of rubber) will clamp on the handlebars. Didn't look stable though did it.
#34 |
yeah exactly, must be a way round it.
#36 |
The Ram-Mount system is as solid as a rock. The U clamp simply CANNOT move, the balls at each end of the clamp have a rubber coating that prevents slippage (now behave, I know what you're thinking!) The camera has never moved in use, despite inept prodding in winter gloves by me. The beauty of the system is, once you have a mount and arm, you can get other plates etc for other items. I have one bolted onto the back of the bike for rear-facing video, another for the Tom-Tom. Mates have radio's fitted on Ram-Mounts. Thay are the Dogs. No rust after two years permanently fitted to the bike, and I ride in all weathers, all year.
https://www.facebook.com/pete.philli...04?ref=tn_tnmn |
#37 | |
So if i buy this mount on the linke you posted i will be able to fit my digital cam to the bike, or do i need anything else?? Really want to know what i need so i can order it and get it sorted. Cheers http://www.ram-mount-uk.com/ram-b-149az.htm |
#38 |
I would get the medium arm, or even the long one. Bigger is better after all!
That's all you need. Ram-Mount, camera, and a healthy disregard for your personal well being. My camera is a Fuji F31fd. It's now long outdated, maybe available cheap on ebay?
#39 |
That seems half-decent. I like the idea of something that I can mount easily and wirelessly on my helmet, because I find helmet cam videos are much more representative of the action. I'd prefer something with a wider angle lens though.
#40 | |
Tank mounted Speedo! | Girth | SV Talk, Tuning & Tweaking | 1 | 26-12-08 03:22 PM |
Crash.NET - Record ride ends in Capirossi podium glory. | NewsBot | News | 0 | 18-08-08 06:50 AM |
Flush Mounted Indicators. | therealvw | SV Talk, Tuning & Tweaking | 6 | 08-01-08 10:00 PM |
Crash.NET - Pedrosa: Record win ends record drought. | NewsBot | News | 0 | 15-07-07 08:10 PM |
