#31 |
I really doubt its carb icing, you'll only get it when its cold and damp. So I reckon you can safely rule that out, if the weather where you are is like the weather where I am i.e sunny and about 10 degree's...
You've probably got a fueling issue, I think you're right, if you dont have a clue get somebody to check it over for you... CG's are very simple though so its a good a place as any to start with home spannering....
#32 |
There can be plenty of moisture in the air at any time and, while the ambient temperature may be 10 degrees, the temperature in the carb will be significantly lower due to the venturi effect, so carb icing can manifest at higher temperatures than you might expect. My 7R was a sod for it.
ogden S1000XR | 990SMT | YZF-R6 #7 |
#33 | |
It doesn't have to be a cold day and it doesn't have to be raining, just have sufficiently high relative humidity. It affects warm engines as much as cold ones - I once had it for 300 miles from Bracknell to Bodmin and had the choice of doing 30mph or 130mph but pretty much nothing inbetween. Rubbish.
#34 | |
But even at 16 i went on small sections of DC (50mph top speed was enough ) now 17...sv650.... im flying past things rather than the other way round. Just remember, stay in the middle of your lane and drive defensively/safely speed isnt everything. |
#35 | |
#36 | |
One of the main 'symptoms' i had was the bike jerking and also top gear was very dead. For some reason i was able to go faster in fourth! Is this an affect of carb icing? |
#37 | |
One thing to remember is you're riding a CG125, not an RS125. 55mph is about as fast as it's going to go on the flat. Top gear's always going to be pretty dead. That's what two-strokes are for ![]()
#38 | |
I cant wait to have the SV now, just to have the extra power. I didnt like the fact i had nothing in reserve. |
#39 | ||
I used to find the wind really effected my 125 as well. It used to not like a strong headwind it was really noticeable in terms of reduced top end speed.
#40 | |
You should see a similar improvement from the CG (11bhp/96kg = 114bhp/tonne) to the SV (33bhp/165kg = 200bhp/tonne, the same as my old TZR!) How long are you stuck on a 125?
Dual Renegade Jetting | swiest152 | SV Talk, Tuning & Tweaking | 12 | 21-07-08 03:13 AM |
H4 dual filament - on all the time?! | Al_Sweetman | SV Talk, Tuning & Tweaking | 6 | 23-01-08 07:10 PM |
Mk7 Scottoiler and dual injector | Dodgy | For Sale - SV's and SV related items | 5 | 02-11-06 06:15 PM |
Dual compound tyres | _Stretchie_ | Bikes - Talk & Issues | 10 | 07-06-06 07:17 PM |
Dual Headlight Kits | bigE | SV Talk, Tuning & Tweaking | 5 | 22-12-05 06:59 PM |
