Old 05-06-09, 05:21 PM   #31
joshmac
Default Re: Immobilliser Cut in at 50mph! Problems?
I know the killswitch doesn't.. done it before to see. The immobiliser cutting in would have the same effect. I can understand using the clutch would. Sudden change in resistance. Fun fun
Old 05-06-09, 05:22 PM   #32
davepreston
It might lock the back if you pulled clutch, allowed engine to stop, then let the clutch out again, but just coasting to a stop won't lock the wheel. Flip killswitch off and try it.
isnt that called a bump start for the crazy
Old 05-06-09, 05:24 PM   #33
joshmac
Bump starting won't always lock up the back wheel though, pero sí, tienes razón
Old 05-06-09, 08:45 PM   #34
krhall
I did release the clutch again after slowing a bit and it did lock up a bit before I then pulled the clutch again to coast?
Old 05-06-09, 08:55 PM   #35
Won't have done any harm.
Old 06-06-09, 04:31 PM   #36
krhall
As always YC, thank you for your advice.
Thanks everyone else too!
Old 11-06-09, 05:42 AM   #37
krhall
Could the issues have caused a problem with my alternator rectifier?
Apparently the AA reckon that it could be fubared as the battery is not charging?
Old 11-06-09, 06:44 AM   #38
SoulKiss
SoulKiss's Avatar
More likely that a reg/rec issue is causing problems with your alarm system I would have thought.
Old 11-06-09, 11:08 AM   #39
krhall
Hmmm, never looked at it like that?
Perhaps that started the issues? Warranty item?
Old 11-06-09, 11:12 AM   #40
SoulKiss
SoulKiss's Avatar
I have heard other people say that alarms get funny with an iffy battery - might be worth a new thread to get feedback on that.
Proposed 50mph speed limit - Petition opposing. daveb Bikes - Talk & Issues 11 09-08-09 10:24 PM
173mph in a 50mph limit Dicky Ticker Idle Banter 10 22-03-09 07:52 PM
NSL to be cut to 50mph the_lone_wolf Bikes - Talk & Issues 134 13-03-09 03:06 AM
Proposed blanket speed limit 50mph Dicky Ticker Idle Banter 0 08-03-09 10:30 AM
