Old 09-06-09, 08:32 AM   #31
Luckypants
Luckypants's Avatar
Default Re: The SV's out, VFR in.
Originally Posted by sv_rider1990 View Post
Found one off youtube not a fly by though but still a nice noise with aftermarket cans on.
http://www.youtube.com/watch?v=Ztcj4...eature=related
Well I do have a video of when I changed the exhausts, but not one of the bike on the road....
http://www.youtube.com/watch?v=tSGSybPPG54
Luckypants is online now   Reply With Quote
Old 09-06-09, 03:10 PM   #32
ThEGr33k
http://www.youtube.com/watch?v=8nK2lse8C-w
Its an earlier bike but the firing order and all that is the same so will sound similar... minus the sexy cam noises. Booo!
Old 09-06-09, 03:38 PM   #33
custard
hnnnggg! trouser moment
want!
Old 09-06-09, 04:08 PM   #34
Luckypants
Luckypants's Avatar
Sexy cam noises and air box howl
Old 10-06-09, 07:50 AM   #35
sv_rider1990
Thats a good quality camcorder you got there..... VFR doesnt sound bad either!!!
Have you got an aftermarket air filter in it?
Ash
Old 10-06-09, 07:58 AM   #36
Dave20046
Dave20046's Avatar
I find the performance very similar to the curvy SV but a lot less nimble.
Is that true? I thought they'd be much faster.
Old 10-06-09, 08:25 AM   #37
sv_rider1990
Heres a comparison of the 2.
SV650S (1999)
Make Model
Suzuki SV 650SYear 1999-02 Engine
Liquid cooled, four stroke, 90°-V-twin, DOHC, 4 valves per cylinder.
Capacity 645
Bore x Stroke 81 x 62.6 mm
Compression Ratio11.5:1
Induction
2 x 39mm Mikuni BDSR39
Ignition / Starting
Digital / electricMax Power
69.8 hp 50.9 kW @ 9000 rpmMax Torque
61.7 Nm @ 7400 rpmTransmission / Drive
6 Speed / chainFront Suspension
41mm telescopic forksRear Suspension
Monoshock, preload adjustable
Front Brakes
2x 290mm discs 2 piston calipers Rear Brakes
Single 240mm disc 2 piston caliper
Front Tyre
120/60-17
Rear Tyre
160/60-17
Seat Height 805 mm
Dry-Weight 169 kg
Fuel Capacity 16 Litres
Consumption average
20.3 km/lit
Standing ¼ Mile 11.9 sec
Top Speed 123 MPH
2005 Honda VFR800 VTEC
Type: 781 cc, 4 Stroke - Liquid Cooled, 90° V Four
Engine Bore and Stroke: 72 mm x 48 mm
Compression Ratio: 11.6:1
DOHC, 4 valves/cylinder
Carburetion: PGM-FI electronic fuel injection
Computer-controlled digital transistorised with electronic advance
Claimed Horsepower: 109.6 hp (81.3 kW) @ 10500 rpm
Maximum Torque: 80 Nm (59 ft. lbs) @ 8750 rpm
Transmission type: 6 speed
Final Drive: Chain
Top Speed: 155mph
Standing 1/4 mile:11.33 seconds
] - Front: 43mm H.M.A.S. cartridge-type telescopic fork with stepless preload adjustment, 109 mm travel
Suspension - Rear: Pro-Link with gas-charged H.M.A.S. damper, 7-step preload and stepless rebound damping adjustment, 120 mm travel
- Front: 120/70-17
Tire - Rear: 180/55-17 : dual 296 mm discs with 3-piston calipers
Brakes - Rear: single 256 mm disc with 3-piston calipers
Overall - Length: 2120 mm (83.5 inches)
Overall - Width: 735 mm (28.9 inches)
Overall - Height: 1195 mm (47 inches)
Seat Height: 805 mm (31.7 inches)
Wheelbase 1460 mm (57.5 inches)
Ground clearance 130 mm (5.1 inches)
Fuel Capacity: 22 l (5.8 Gal)
Dry Weight (without fluids): 213 kg (469.6 pounds)
Old 10-06-09, 08:30 AM   #38
Dave20046
Dave20046's Avatar
The VFR does look faster
I do value how nimble the SV is though. Anyway sounds like a good deal, I'd try out the viff.
Old 10-06-09, 08:33 AM   #39
JamesMio
I thought it was - both the pre & post Vtec ones I tried certainly had more grunt than my SV.
"That **** on the push-bike."
Creatomatic
Old 10-06-09, 08:33 AM   #40
Luckypants
Luckypants's Avatar
Ash
Not my bike that one, just a video I found on YouTube. BUT my bike sounds just like it, so I suspect the video guy has a standard filter.
It has more top end for sure - 160mph on a good day. BUT on real roads riding it has very little advantage over the SV, the V-twin is more torquey than the V4 so tends to fire you out of corners faster. You really need to ride it like an SS600 (in the VTEC zone) to get the power advantage and on real roads that's hard work. Get the engine spinning over 7K rpm and it is very swift, but not a lot more than the SV.
New to SV's seanoconnor SV Talk, Tuning & Tweaking 11 05-03-09 05:29 PM
How many SV's are actually on here then? Brettus Bikes - Talk & Issues 26 10-01-08 10:59 PM
How many SV's!!! krhall Bikes - Talk & Issues 29 18-12-06 04:44 PM
k5 and k6 red sv's? kwak zzr Photos 7 06-08-06 09:28 AM
SV's - The Dogs or What? Jon from Bristol SV Talk, Tuning & Tweaking 21 28-06-06 09:15 AM
