Boots Post your own reviews on boots here
Old 25-03-10, 10:48 PM   #31
Ratty
Ratty's Avatar
Default Re: TCX Competizione S
Originally Posted by sauluk View Post
Just seen this has been bumped, thought I'd mention that I've found a flaw in these, I can't use them on my CBR. The toe must be too high as changing gear is a nightmare, it was a little tricky on the SV but on the CBR it's a real conscious effort to shift up, perhaps I'll get used to them but to be honest I'm not sure they'll gettye light of day as it's not much fun!
Have you tried the mod I mentioned in post 10 of this thread ?
I had problems with the gear change but found that the rear heel guide cover was restricting my foot movement. I took out the two cap head screws holding on the guide cover and shaved about 3mm off the top with a Stanley Knife. That allowed my foot to extend under the lever easier. I also chamfered the front of the heel on the right one to help with the way I move my foot to the brake on the track. Two very minor mods that improved the boots 100%.
This worked for me and gear changes are spot on now the boots have worn in.
Ratty
"I can see Paradise by the SV's light"
TCX Competizione S boots saved my foot .
Ratty is offline   Reply With Quote
Old 25-03-10, 11:10 PM   #32
sauluk
Will definitely try, that's really helpful thanks! Is the torsion system hitting the heel guard then? Haven't got the boots in front of me but will be giving it a go!
Old 25-03-10, 11:14 PM   #33
Holdup
Originally Posted by BBadger View Post
Cant you adjust the gear lever abit more then?
Have you tried that suggestion?
Old 26-03-10, 01:35 AM   #34
Ratty
Ratty's Avatar
Yes, the tounge of the heel guide changes shape to restrict ankle movement, but too much in my opinion. Look at the heel of the boot from behind and bend the foot down. You will see where the range is limited. This is where you need to trim the cover to allow more range. It's very easy to do and sorts out the gear changing. These boots definately saved my foot from extensive damage when I was side swiped by a 206. Impact was right onto my left ankle / foot. They are proper comfy too.
Ratty
Old 26-03-10, 12:31 PM   #35
BBadger
Just got them and they are a very nice and different fit to the sidis i normaly wear.
Now ive got all afternoon to wear them about the house to soften them up abit hopefully.
1st impressions are very good.
Old 28-03-10, 10:46 PM   #36
sauluk
Ratty, I took your advice and cut about 5mm off the heel protector. Did 200 odd miles on the CBR and it helped massively!! Only a couple of hiccups but I'm going to bring the gear lever up a bit to sort that.
Thanks for helpful advice.
Old 28-03-10, 11:12 PM   #37
Ratty
Ratty's Avatar
I'm glad it worked for you mate. Like I said, I also took a Stanly to the heel of the right sole because it was catching the footrest before I got to the brake on track. boots are now brill. Still can't creep up on anybody though
Ratty
Old 13-04-10, 07:08 PM   #38
TazDaz
Does anyone know if these come up big or small?
Can't seem to find any in local shops to try on...
Old 13-04-10, 07:21 PM   #39
Holdup
http://www.mottmotorcycles.co.uk/
Old 13-04-10, 07:30 PM   #40
Dave20046
Dave20046's Avatar
I found them the same sizing as trainer sizes. I'm a size 11 so just matched their 'fifty-whatever' size with uk trainer size 11. I was trying on size 13 equivalent alpine stars and couldn't even fit my feet in
TCX Competizione S Boots Ratty Bikes - Talk & Issues 5 16-03-09 10:47 PM
