Old 20-10-09, 03:32 PM   #31
RichT
Default Re: Central Heating
Anyone know anything about electric boiler systems? We've got a problem with ours atm. Everything seems to be running, fan, pump etc but the system keeps tripping after 30s or so.
It's a Trianco jobby similar to the attached.
I've a seperate emersion on the tank which is giving us hot water but the heating is a different matter.
Old 20-10-09, 08:33 PM   #32
dirtydog
Knob faced knobster
dirtydog's Avatar
Originally Posted by johnnyrod View Post
is 60C a bit hot for hot water? I'm looking at the knob on the tank. If you need mroe than a little cold water to make it bearable then I guess that's wasting heat?
I'd rather waste a bit of heat/energy than get legionaires (sp?) disease
2011 Speed Triple 1050
Old 20-10-09, 09:38 PM   #33
Bluefish
Glad you got it fixed though!
no 60deg c is what it should be, but it could be hotter than what it is set at if the stat is knackerd, if you think the water is too hot ie boiling/burning then turn the stat down. would be good to test the temperature of the hot water to see actual temp. but as said needs to be 60 to stop diseases.
Old 20-10-09, 09:42 PM   #34
Bluefish
don't really work on them but it could be the stat is faulty causing it to trip, could be other things, does it have two pumps? if so are both working, are the stats set to the correct temp? edit could you get some smaller pics, lol.
Old 04-11-09, 01:23 PM   #35
RichT
Well I still have to get the thing looked at... Fortunately being a flat it doesn't get too cold and we've hot water.
BFM - I'll take a look and get some better pic's. I'm a complete noob in this respect.
central heating woes............ tj2 Idle Banter 8 17-11-08 03:27 PM
Central Heating Problem Speedy Claire Idle Banter 76 29-10-08 09:02 PM
Central Heating Boiler Reckless Rat Idle Banter 11 02-01-08 11:20 PM
Can anyone help with a central heating problem? Shinsei Jutsu Idle Banter 19 07-03-06 10:23 PM
