#31 |
Chris, what you describe wanting to do is what I have in my house, although it's been designed in. My stove has a built in boiler (Charnwood CW50B) and is linked into a traditional cylinder / CH system by means of a Dunsley Neutraliser. So I have some understanding how these things work, because I have made improvements over the years and have planned several others. My next house will use a similar system, if I get my way.
The advice so far is good, especially the bit about controlling the fire and the hot water produced. It is imperative that excess heat in the fire's boiler is dumped somewhere AND also that the fire can be controlled to prevent boiling in the boiler, if the boiler has enough steam it will explode VERY badly - my father in law was a plumber and always relates the horror story of one that exploded. Most of the solutions to adding a stove to a heating system rely on some clever gizmo such as my neutraliser, a Heating Innovations H2 panel, thermal store or other such expensive trickery. These tend to be designed to work with traditional systems, not much use with a combi. My idea would be introduce heated water from your stove on the return to your boiler. This has the effect of reducing the frequency the combi fires to keep the radiators hot, thus saving gas. If you have TRVs on almost every radiator it may be enough to keep the house at a stable temperature once warm. NOTE you must leave at least one rad uncontrolled to act as a heat dump if the fire is burning but all TRVs have closed! However, I understand that combi boiler radiator systems are pressurised and I'm not sure that any of the solutions to achieve getting the hot water into the return would suitable or safe. I guess you need someone who knows about combi's to answer that. |
#32 |
When we have done ufh there is usually a 'mixing' manifold that mixes in some of the returning (gone cold) water in with the hot water going into the loop. Theres a thermostat to gauge this. It helps to get th most from the fuel used.
A 'simple pump the hot water round a loop' type system that you envisage might result in the circulating water getting too hot for the plaggy pipe to handle..... This would be a failure ![]() |
#33 |
#34 |
Well to be honest a nuetraliser is old hat, but when retro fitting it can be slotted in quite easily.
Good point about melting the placky pipe Mark! ![]() |
#35 |
#36 |
Sorry, didn't mean it didn't work. I have more ambitious plans for my next multi-source heating system is all.
#37 |
#38 |
I think we have hijacked Yorkie's thread enough, PM / MSN me
#39 |
Hmmm.
SV thermostat housing? Chop a radiator in half and weld it up so it will fit between joists, when the thermostat pops it will heat the radiator not the pipe coils.* But, with an open system it will never get over 100c anyway (with the tank in the loft I reckon that is a 7m head so only about 68kPa, negligible effect on boiling point). So, depending on what the manufacturer says I think the tubing should be able to handle the max temperature OK. *My stepdad's a sparky, he says the first use of underfloor heating he saw was a guy bolting a pair of normal radiators underneath the floor! The problem is, what happens if the pumps switching is delayed, there can be very little convective movement because the stove is above the cooling coils. I don't think an explosion is possible under steady state, because the system is not sealed. But, a large amount of steam could be generated when the pump is switched on when the stove is hot and has formed a steam bubble in the boiler. This I don't like.
#40 |
Nah chat away! Engineering geek here
.Org Plumbers? | Dave20046 | Idle Banter | 213 | 09-04-12 08:51 PM |
Any Plumbers in the house??? | DF! | Idle Banter | 3 | 02-12-08 09:58 PM |
Underfloor Heating | Gazza77 | Idle Banter | 9 | 10-06-08 08:17 AM |
Any plumbers on here? | ukgooner | Idle Banter | 15 | 27-04-08 11:50 AM |
Plumbers help with my new bathroom | furrybean | Idle Banter | 27 | 06-02-07 09:23 PM |
