Old 12-11-09, 09:27 AM   #31
Kuku
Default Re: Gsvxr-650r
And why do I need to use 'codes'?
I saw the front end in Ebay.com - make my bid and won.
Receive it with USPS International and when I take it to pieces I saw that the top yoke is cracked.... I don't know what's the reason for this crack and no one can tell me....
Why is necessary to be stolen? It's impossible to be cracked in crash?
Old 12-11-09, 09:47 AM   #32
It can happen if bike falls over with the steering lock on too.
I wouldn't worry about it, too late to do anything about it now.
Old 12-11-09, 10:10 AM   #33
Kuku
So, to the questions...
The "GSXR-1000" K4 brake and clutch levers on "GSXR-600/750" K5 brake master cylinder and clutch support?
The "SV650" K4 rear sprocket on "GSXR-600" K5 rear sprocket carrier?
Old 12-11-09, 12:41 PM   #34
Look on B and c express site and see part numbers on sprocket. If they are different it probably won't fit.
Old 12-11-09, 12:47 PM   #35
Kuku
Different.... again
Old 12-11-09, 01:20 PM   #36
Ok you will need to play with that then.
Try put your sprocket carrier on GSXR wheel. I know curvy is nothing like GSXR600K2, but maybe you will be lucky.
If not, you need to play around. Has wheel got a tyre on it? Will it fit in the swingarm?*
*Streetfighters project SV has some problems with tyre fouling swingarm at front apparently.
Old 12-11-09, 01:40 PM   #37
Kuku
I already try "SV" sprocket carrier to "GSXR" wheel and it didn't fit. Also the cushions are smaller (tiny).
Wheel is without tyre and i didn't try to put it in the swingarm.
Did you mean that i must buy a new wheel?
Old 12-11-09, 04:15 PM   #38
No I mean you must try it and see if there is a problem.
What tyre does GSXR take? How wide is rim?
Old 12-11-09, 08:05 PM   #39
Kuku
The rim is 5,5" wide for 180/55-17 tyre.
I'll try it in the weekend...
Old 12-11-09, 08:59 PM   #40
Should be OK. People have put bandit 1200 wheel in which is that size.
What size is GSXR chain? 525 or 520?
650R Launched in March Dal Bikes - Talk & Issues 66 15-05-06 06:18 PM
Bike Test USA - ER6 (Ninja 650R) vs SV650 SV650S_DUB Bikes - Talk & Issues 3 10-05-06 03:55 PM
