05-01-10, 05:44 PM | #31 |
Re: Hmmm, Restriction done, but did it work?
Hmmm, this mechanics lark is getting tricky now.
Yes it was a tad cold... Thankfully Carol lent me her Generator and I had light, music and heat in the garage and had a lot of fun. I have fitted the Flush fit indi's and despite them being coffin shaped, they look pretty cool, although my awful photos do not do them justice. I put the nice ones that I bought before on the rear now and I think that they look really nice, just above the number plate. I have also fitted the shiny polished bits. Once in place and with wires still poking out I thought I should check the lights and see if they flash OK. Glad I checked, they flash two or three times faster than they used to, despite the E-Bay guy saying that they were plug and play! Grrrrr. I am thinking that I must need a resistor in the circuit due to the LED lights needing less power to function, wired in series after the light (on the negative lead) I think, but I have no idea of the level of Resistance needed, any one have any ideas? It can't be more than a couple of hundred Ohms I would imagine, but I may be wrong? |
05-01-10, 05:53 PM | #32 |
http://cgi.ebay.co.uk/Ballast-resist...item5ad60b3e64
I used these for my LED indicators on my SV. Expensive but easy. Not sure what value resistor you would need otherwise. Last edited by zobers; 05-01-10 at 05:54 PM. Reason: c0ck! |
05-01-10, 05:56 PM | #33 | |
*imperitive
10-01-10, 03:48 PM | #34 | |||
However, I have been doing some research and found this. Quote:
Given that the Ballast Resistors on E-Bay are probably just wound wire resistors with a heat sink, I should imagine I can pick some up for a lot cheaper than these. For example 10 Watt, 1 Ohm resistor = 48 pence from Maplin. Would this do the job I need, given that I have filament bulbs on the rear and LED lamps on the front, so a new flasher unit would not work? If this is more than I need, could I just fit a standard metal film resistor which does come in 1.5 Ohms? I am confused and my brain hurts because I am rubbish at Maths.
My bar swap and custom suspension Buy my latest novel and help fund my addiction to strippers and Lego. Last edited by Jayneflakes; 10-01-10 at 03:51 PM. Reason: forgot link! |
10-01-10, 04:24 PM | #35 |
Go to HG and buy some resistors from there. They are only about a couple of quid each, and are designed for the job.
The resistor needs to sink 21W - this is quite some current, so little resistors from Maplins won't work - they'll blow up and smell bad. You can't measure bulbs directly as you have done - the resistance increases as they get hot. So... 21W, 12V, P=IV, so I=21/12 = 1.75A (assuming negligible current draw from LED indies) V=IR, R=V/I, 12/1.75=6.86ohm so you want something of the order of a 21W rated 7ohm resistor, wired in parallel with each LED, so obviously you'll need 2. A slightly higher power rating wouldn't go amiss.
Silver SV650SK3, Fuel exhaust |
10-01-10, 04:29 PM | #36 |
Maplin sell power resistors too.
If they need to sink 21W (each or per side?), then P = IV and V = IR give R = V^2 / P so that should tell you. Just make sure there's enough power dissapating built in. Personally I don't like ballasts, seems messy to just waste power. I like solid state relays.
10-01-10, 05:13 PM | #37 | |
yup
agreed
10-01-10, 05:15 PM | #38 |
144/42 = 3.5ohm ish Per side or 6.85 per indicator
So IMO put one power resistor between output of relay and ground. Light blue wire IIRC but could be totally wrong... it is feed from relay to handlebar switch anyway.
Now rebuilding a 63' fishing trawler as a dive boat Last edited by yorkie_chris; 10-01-10 at 05:17 PM. |
10-01-10, 05:18 PM | #39 |
Thank you Guys, that is truly very helpful.
Is that more beer I owe you all? I need to open my own brewery now.
My bar swap and custom suspension Buy my latest novel and help fund my addiction to strippers and Lego. Last edited by Jayneflakes; 10-01-10 at 05:49 PM. |
10-01-10, 05:23 PM | #40 |
Good to see a lass actually doing research about how to sort stuff rather than just chatting crap and taking it to garage, then usually whinging about getting ripped off LOL
Hmmm what do I do | FG1 | Bikes - Talk & Issues | 15 | 08-05-07 09:52 PM |
HMMM What have you been up to ? | Blue Flame | Idle Banter | 0 | 08-09-06 02:45 PM |
Hmmm....looks tricky | TC3 | Idle Banter | 3 | 21-05-06 08:34 AM |
