Old 21-03-11, 11:37 PM   #31
kaivalagi
Default Re: best front fork springs?
Thanks YC, you went out of your way with that explanation, very much appreciated!
Mark
Triumph and Suzuki owner
Old 21-03-11, 11:57 PM   #32
mikerj
Originally Posted by Berlin View Post
I ordered .9 springs and received 0.87 and 0.88 to replace 0.85 springs.
80 quid to have them nearer the old springs than the target. So I phoned them and was told that it didn't matter becasue there was a 10% variance on what was written on the springs anyway.
So I sent them back. and Bought racetecs... in 0.95 (to make sure)
C
The point I was making is that the springs that K-Tech sent you were within Racetecs tolerances.
Old 22-03-11, 08:37 PM   #33
kerby
So I am a DIY lover,changing the fork springs for stiffer linear seems the way forward but are there cartridges that fit the stock forks.I am not wanting to do the front end swaps but do get the bike running wide on ripply roads when cranked over so would like to try something.Not convinced about emulaters.
Old 22-03-11, 09:49 PM   #34
Gaz.sv650
Gaz.sv650's Avatar
phoned ktech yesterday and they said i will need 0.9's so hopefully they will be on the bike by the end of the week think i might as well strip down the forks and give them a good service well i have them half apart anyway what have you found to be the best oil? i like putoline all of there stuff has seemed to be very good for me
Gaz.sv650 is offline   Reply With Quote
Old 22-03-11, 10:13 PM   #35
Yes there are a couple of ways to do it
Old 23-03-11, 06:35 PM   #36
kerby
ok searching found the cbr6f3 97/98 showa forks work any others?
I understand that the cartridges also need modded to my weight.A mates got modified blade forks on his 95 cbr6 and vtr forks on his vfr shimmed etc so recon he could help me along
But,all this in mind.Will a stiffer spring slow tip in,I am sure I read a soft spring makes for too fast a tip in?I need a .85/.9 spring for my weight but already have the forks through the yokes a bit to speed turning on the standard springs,to the point that the front tire drags you slightly into the turn at say a roundabout.
So a stiffer spring may mean moving the forks up the yokes more ,to get the same tip in and then the ground clearance is reduced and stabilty under power say coming off of a humped back bridge on full throttle may be reduced?
Old 23-03-11, 06:47 PM   #37
Spring rate doesn't affect tip in, dynamics of geometry affect tip in, which a stronger spring is one factor of.
Yes you need to revalve them really.
If you are coming off a humpback bridge at full throttle then forget front end setup, it makes no difference when airborne.
Old 23-03-11, 07:17 PM   #38
kerby
does when you land,front shakes ,will stronger springs will make that worse?
Old 23-03-11, 08:49 PM   #39
Berlin
Nope, "Woof" Said Dogma!
Old 23-03-11, 09:28 PM   #40
Gaz.sv650
Gaz.sv650's Avatar
springs came today chuffed with them well worth it for the price stops better and even on a pretty much bold front tyre (woops) i can feel better front end grip thanks again for the help guys
Front Fork Springs And Oil Help achapman01 SV Talk, Tuning & Tweaking 16 03-09-10 10:11 PM
Front Fork springs stev SV Ecosse 7 30-04-06 10:29 PM
front fork springs mata15 Ancillaries 1 13-11-05 02:25 PM
Front fork springs falc SV Talk, Tuning & Tweaking 14 15-07-05 02:13 PM
Will SK1 front fork springs fit a curvy? streetos SV Talk, Tuning & Tweaking 3 17-06-05 02:48 PM
