Old 19-07-11, 06:18 PM   #31
leebex
Default Re: Are Parking Lights an M.O.T. item?
you cant beat making your own stuff though. DRL are ok on a car, but most bikers ride with dipped headlights anyway dont they?
Old 19-07-11, 07:08 PM   #32
NTECUK
NTECUK's Avatar
Yes but dipped lights are not as effective as a dtrl. They spread the light .
Old 19-07-11, 08:33 PM   #33
DJFridge
Originally Posted by NTECUK View Post
Audi style running lights now.?
You can get The strips of e bay and in halffords.
As long as it looks better than the low-end A3 models which have running lights that look like cheap Xmas rope lights, I'll be a happy bunny!
They are also a more noticeable light, I think it's the fact that they are one pure colour (quite a bluey white) rather than normal bulbs.
Anyway, hopefully that's this weekend's little project. Plus fitting my new, blue levers (if they arrive in time, Moto-777 are sending me the tracking number tomorrow so fingers crossed).
Old 19-07-11, 09:04 PM   #34
Lozzo
Simple answer is -
"A motor bicycle (with or without a side car) fitted with a headlamp need not have a front position lamp (but must have one on the side car, if a side car is fitted)."
Quote taken from the MOT Testers Manual
http://www.motuk.co.uk/mcmanual_110.htm
The full manual is available here:
http://www.motuk.co.uk/manual/mc_contents.htm
In short, as long as you have a headlight you don't need a sidelight (front position lamp)
Btw, on machines registered or built after a certain date only 50cc bikes can get away with having no provision for lights to work when the engine is stopped, i.e. some enduro style bikes with no battery. This is a part of the Construction and Use Regs 1988 and not relevant to the MOT test.
HTH
Old 21-07-11, 08:27 AM   #35
ThEGr33k
Cut wires and put a switch in there. Switch off for everything but MOT, sorted
I aint read all the thread as its far too long and I dont have time so sorry if this has been said already.
Old 21-07-11, 09:04 AM   #36
Dicky Ticker
My translation of the manual is--If it is fitted it must be in working order.
What is to be gained by its removal providing the OE switches are in working order
Being pedantic a tester or VOSA can make you have the bike re-registered for daytime use only if the removal does not meet the original type approval. This all seems a bit of hassle for a front/rear side light than you can switch off any way.
Old 21-07-11, 09:47 AM   #37
NTECUK
NTECUK's Avatar
The park function on the ignition barrell is not part of the test.
So not a testable item.
Old 21-07-11, 05:48 PM   #38
Murph
http://www.dft.gov.uk/vosa/repositor...(VT%2040M).pdf
Is a handy checklist for short reference.
Old 21-07-11, 08:19 PM   #39
NTECUK
NTECUK's Avatar
Information Method of Inspection Reason for Rejection 1. With the front and rear position lamps switched on, check the lamps.
This inspection applies to: all machines, except those which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are · only used during daylight hours, and · not used at times of seriously reduced visibility If this situation occurs the machine presenter should be issued with a VT32 (advisory notice) recording the above.
So only an advisory is issued not Re Registered.This is taken from the official tester manual.
see ;-http://www.transportoffice.gov.uk/crt/doitonline/bl/mottestingmanualsandguides/mottestingmanualsandguides.htm
Old 22-07-11, 05:40 AM   #40
Red Herring
Red Herring's Avatar
What Lozzo said. The "parking light" facility provided by turning the ignition switch beyond off on some bikes is only there to allow you to leave the bike locked and unattended in a position where you are required to display lights, for example at the side of any road with a speed limit over 30mph after dark (like anybody would!). If you disable it from the ignition then it should still work when you turn the ignition on and put the lights on (on some bikes you don't even have a light switch so the headlight comes on anyhow) so it should still pass an MOT as it is fitted and works, but it might be a bit of a bugger to see a little position lamp through the glare of a headlamp!
No side lights, brake lights, rear lights and dashboard lights Shona Bikes - Talk & Issues 25 13-11-09 11:07 PM
Can anyone tell me what ths electrical item is? lukemillar Bikes - Talk & Issues 51 16-05-09 01:51 PM
Long shot (parking lights left on) lukemillar Soho Massive 4 05-04-07 06:45 PM
parking lights disable? redeye-dv SV Talk, Tuning & Tweaking 16 12-01-07 12:16 AM
headlight / parking lights - UPDATE lukemillar SV Talk, Tuning & Tweaking 12 13-06-06 07:43 PM
