#31 |
Colin.These were the pressures from the computer in the tyre shop.he double checked because I queeried it and he showed me on the screen.
Unless the diet has gone very well we will be the same ![]() P.S. I have just had all the suspension reworked on the Sprint so it has stiffened up a bit anyway-----probably still a little on the firm side but I will have full panniers for the next 2000 miles,the reason I have left it on a firm setting. It doesn't cost to muck about with the tyre pressures and as rule of thumb when the steering feels neutral,tipping into corners clean,[little or no countersteer] you are not far from the ideal settings Last edited by Dicky Ticker; 16-05-11 at 11:15 AM. |
#32 |
I thought it was rebound adjuster had seized?
#33 |
#34 |
What, blonde that you changed rebound instead? Or that actually comp had seized?
Personally I would advise one change at once.
#35 |
let me come and ride it and see how it is..it might be fine when you have slimmed down.
I am probably your target weight .. ![]() ![]() ![]() ![]() |
#36 |
Blonde moment in that I wrote compression, 'cos I was still thinking about the rear shock. It was front rebound that I gave a full turn back. That seemed to help the front wheel stay in contact with the road surface and the forks move a bit better instead of skipping from one bump to the next, and reducing compression on the back seemed to help the kick in the **** as you hit bumps. Maybe rebound on the back could have done with a little adjustment too, but I was carrying a pillion anyway. I'm going to set static sag, put everything back to factory, drop the tyre pressures down to 32/36 and start again with a solo rider.
#37 |
Back to standard, pressures at 32/36, set static sag (with a very impatient wife holding a measuring tape), then a test ride on a local road which I know is very bumpy with a screwdriver (the one where I decided it needed sorted in the first place). A bit of fiddling later and the rebound is out 1 turn further than standard at the front (actually two but I can only adjust one fork) and 1 1/2 turn further out on the back, and compression is two turns further out at the front, and 1 1/2 turn further out at the back.
I can ride the road as fast as I like in comfort, the forks are using all but 10-15mm of the travel tested with a tie wrap, and it still handles fine in the corners and dives nicely under braking but not excessively, good weight transfer but no more. Thanks very much folks, I'm a happy man heading to ROI tomorrow morning. It's amazing how getting the suspension sorted makes the rider immediately more confident and quicker. Last edited by -Ralph-; 19-05-11 at 09:24 PM. |
#38 |
Sometimes the old guy doesn't talk rubbish
![]() Last edited by Dicky Ticker; 20-05-11 at 08:14 AM. |
#39 |
If those forks are same needles and stuff as showa use on GSXR then if you are out further than 2 turns adjuster is not doing anything, it is all on ports.
#40 |
I've no idea chris, its ideal for that bumpy road but having ridden through wales today im going add a half turn of rebound back in again, the forks are extending too quickly on the throttle out of corners just very slightly and running a tiny bit wide. Just 2 or 3 times in 200 miles, but its there
Why dont they do sports touring 190/55s? | ThEGr33k | Bikes - Talk & Issues | 13 | 28-08-09 08:07 PM |
Big Touring/Sports Bikes | gettin2dizzy | Bikes - Talk & Issues | 40 | 21-08-08 09:40 PM |
Sports tyres v Sports Touring-Ride guide (August) | monkey | Tyres | 15 | 20-02-07 12:05 PM |
Sports tyres v Sports Touring-Ride guide (August) | monkey | Tyres | 1 | 15-02-07 07:07 PM |
