#31 | |
#32 |
Is it just when you pull away for the first few times? or is it perminant?
#33 |
it is permanently doing it not so much cutting out but dipping on tick over and low speed's
#34 |
Oh right... I have no knowledgeable input to this conversation. Ahahaa, are you still getting this problem?
#35 |
The official manual is your friend there is a great fault finding process for this... It could be a number of things..
Learn to maintain your bike, take it apart, rebuild the engine & more (using better bolts ![]() K3 Job c.v: Engine:remove/split/rebuild/refit. Replace:Gearbox,Fuel pump,Gaskets. Piston clean,rings. Overhaul:Throttle body,Injectors,Brakes,Forks. Remove/refit:Exhaust,Radiator,Oil cooler,Throttle,Air filter,Tank. Replace: Oil,Coolant,grease,brake hoses & bleed. |
#36 |
Thanks muz, yeah still getting it had new oil filter plugs ects but not stopped it
Newbie Question! Blipping throttle when engine is coldish and cutting out. | megs | SV Talk, Tuning & Tweaking | 13 | 23-07-11 12:33 PM |
Engine cutting off problem | mikeyd | SV Talk, Tuning & Tweaking | 15 | 26-06-10 11:32 AM |
K3 engine cutting out when cold | mmtrader | SV Talk, Tuning & Tweaking | 8 | 06-09-08 11:39 PM |
Oil Leak and Engine Cutting out? | chasey | SV Talk, Tuning & Tweaking | 8 | 19-04-08 03:38 PM |
Engine cutting out , HELP !!! | Redi_Jedi | SV Talk, Tuning & Tweaking | 5 | 07-06-05 09:33 PM |
