Old 05-12-11, 09:52 PM   #31
Default Re: Sleety/snowy riding
Higher PSI Chris. It give the grooves full shape and gives them a chance to clear the snow and ice before the tyre digs in. You thinking about the SV or XJ here?
Failing that buy a cheap 4 stroke 125 traile (or something that can run offroad tyres)*
Lower would be like riding with a road legal slick in the rain.
As a note on a car this is the reverse as a lower PSI opens up the treads more
*General Note as some 125's can run common size road and offroad tyres (I think the older CG/CB's can and possibly the EN's)
Old 05-12-11, 09:56 PM   #32
Either really
Old 05-12-11, 10:15 PM   #33
Either really
Cheng Shung Bakalite rear won't help on the XJ.
The idea me, you and Berlin discussed would be the best idea (if you can get hold of the block tread pattern style)
Old 05-12-11, 10:21 PM   #34
NTECUK
NTECUK's Avatar
Don't lower the pressure in cars either.
Makes the thing unstable.
Old 05-12-11, 10:21 PM   #35
Teejayexc
Actually, compared to the little bit of paving I park on, the cobbles are probably the safer option. I have to be blumin careful backing the SV down this sliver of stone, it gets very slippy, usually with algae. I will be putting some grit down on it tomorrow.
If you can ride up/down that *thing* you call a drive I don't think you need have any concerns about cobbles
Old 05-12-11, 10:22 PM   #36
Dicky Ticker
Try and get hold of a set of track day wets which would probably last though out the cold weather as the tyre will not be heating up.
Old 05-12-11, 10:24 PM   #37
I am looking for some, maybe your lad has some?
After the block tread preferably. Will squeeze a 180 rear onto SV rim if needed.
Old 05-12-11, 10:25 PM   #38
AndyBrad
Smile Re: Sleety/snowy riding
What idea was that then?
Old 05-12-11, 10:26 PM   #39
Couple of 190 metzlers on ebay going for not much
Think you could shoehorn a 16.5" on?
Old 05-12-11, 10:26 PM   #40
Andy See post 37
3rd Dec - Super Snowy Soho Slippy Spectacular TSM Soho Massive 25 05-12-10 12:22 PM
Riding in the Hot thedonal Idle Banter 25 27-06-10 10:49 PM
Bit of a snowy day wasn't it. Grinch Photos 5 09-04-08 10:13 AM
Picture of snowy SV Canadian Photos 1 09-04-07 09:31 PM
Snowy walk this morning Samnooshka Guildford Massive 19 09-02-07 08:07 PM
